Question about Samsung 204T 20" LCD Monitor
Where can I buy parts for a samsung 204t - Samsung 204T 20" LCD Monitor
  • patio841 Oct 03, 2009
    I need the logic board BN94-00753Z.
    Novelist:
  • 149 Answers
Hello. Try this address...http://www.partstore.com/Model/Samsung/Samsung/204T.aspx. I went there and I feel you'll be blown away by the selection they have!--Good luck!---Rick
Posted on Oct 03, 2009
Testimonial: "Thank you. I got the board number from them."
  • 788 Answers
How about listing what parts you are looking for.
Testimonial: "Thank you. see my comments."
    Scholar:
  • 63 Answers
I have one of these monitors that I could possibly sell you a part from. It's at my shop, but if I remember correctly, there's a problem with the logic-board, so I can offer a power supply and a panel. Let me know what you need...
Chris
Boise LCD
sales@boiselcd.com
www.BoiseLCD.com
Sycmaster 204T works great for 20 seconds then screen blanks
Hello Carl,
That problem could be caused by either bad capacitors on the power supply board or a bad back light bulb in the panel. The first thing to check would be the capacitors on the power supply board. Here is a link with a few pictures of how to dis-assemble the unit and what to look for. The tops of the capacitors should be flat, if they are domed or have any bulging then they need to be replaced. If all of the capacitors look good then it is most likely the back light bulb. This can be replaced by it is much more involved.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Sep 24, 2012 | Samsung SyncMaster 204t 20.1" Flat Panel...
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Samsung 204T monitor hard to start
we need to check first the switch button, remove that and look for replacement. if still encountering problem well proceed trouble shooting ckt side.
Apr 20, 2010 | Samsung SyncMaster 204T Monitor
Samsung synmaster 204t "green board"
Most likely, this is an orientation sensor.
The monitor supports a "MagicRotation" feature, which automatically switches between portrait and landscape mode when the screen is rotated. I think the part you damaged is a mechanical orientation sensor required for this feature. This would explain why it had a loose metal ball inside (shorts two contacts together, depending on the orientation).
So I guess, you should still be able to use the monitor without the sensor. Uninstall the "MagicRotation" utility (if you had it installed at all) and set the orientation manually.
Mar 28, 2010 | Samsung SyncMaster 204T Monitor
Samsung 204T no longer displays
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 24, 2010 | Samsung 204T 20" LCD Monitor
My son crack the LCD glass on his 204T SyncMaster
The glass of the panel is glued or welded to the LCD wafer below, it cannot be replaced separately. Since the panel is the most expensive part of an LCD monitor, its probably the cheapest option to just get a new monitor - spare part ordering and extensive manual work required for the change simply outweighs the remaining value of the monitor.
Feb 09, 2010 | Samsung SyncMaster 204t 20.1" Flat Panel...
Samsung Syncmaster 204T flashing
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Jun 21, 2009 | Samsung 204T 20" LCD Monitor
Blank Screen
It's very likely that the LCd "inverter" is bad. This is a module that provides the high voltages needed to light the 4 cold-cathode lamps that provide the white backlight. Search for other samsung problems with inverter and you should find several. The one I saw was for 17" LCDs and the 204T is probably using a different module. Should be able to find replacement online, but be prepared to take the monitor back cover off, with tiny screws and connectors.
Sep 09, 2007 | Samsung SyncMaster 204t 20.1" Flat Panel...
Samsung 204T 20" LCD Monitor Logo
144 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
