Question about Frigidaire ATF6000ES Front Load Washer
Washer drum is off balance and washer is level.
    President:
  • 1,304 Answers
Check your pump for clogs
you could be over soaping
frigidairs dont like this, 1 tblspoon per load
Posted on Oct 03, 2009
My GE washer GTW460NMKwww, the drum will not balance itself when going into final spine cycle.
Are the clothes evenly distributed inside the drum and the washer not overloaded? The drum is not self balancing, you must take care when loading it to even the weight distribution
Mar 01, 2017 | GE Washing Machines
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Samsung washer wf218anw
Possible that the washer is not stable due to level adjustment. Use a spirit level to set the washer so that it will be stable. Check the drum movement and the motor /drum mountings.If you find there is PLAY on the fittings then it must be reset.
Check this link: Drum Bearings.
Jan 19, 2013 | Samsung WF203ANW Front Load Washer
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Washer wont stay balanced
Possible there is level fault in the floor setting. You can use a simple spirit level and adjust the level of the washer with a tilt to the rear for easy drain. Also check for bearing fault if there is wobbling, check for counter weight or alignment fault of the drum if the frames are rusted.
Aug 23, 2012 | Maytag MAT12CS Top Load Washer
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
When in the spin cycle it sounds like the ceramic drum is hitting the back of the washer, is it off balance?
Make sure it is level and if thats correct then tilt the washer back and look up under it you will see springs and support arond the drum see if maybe on has come off or broke and that is causing the problem...
Nov 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
UE Error wm1814cw
Its probably the drum itself. try rocking the drum or spin by hand some and see if the error clears. If so you probably have a worn out drum support/balancers
Aug 27, 2009 | LG WM1814CW Front Load Washer
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
