Question about Acer Aspire 5100 Notebook
Acer aspire 5100
Started with an hal.dl. error , i deleted partition formated and during setup at different stages the power turns off and quite often i have to unplug it to get it to boot again. Note the power shut down problem even occurred while sitting idle in cmos.
Any thoughts
    Novelist:
  • 188 Answers
Have you cleaned the fans lately? might be really clogged - you can you some compressed air usually you blow from the intake on the bottom of the laptop out the vents in back or side
Let me know if that helps.
Posted on Dec 21, 2007
How can i reformat my laptop acer aspire 4736z i have my genuine vista os can you teach me step by step...
If you backed up your files, boot off the CD, during startup you should see a message "hit any key to boot from CD", hit any key. Follow the setup prompts. When it gets to the partition pick, delete the partition and format it again during setup.
However please be aware there may also be a recovery partition on your pc if vista was installed by the factory
May 12, 2011 | Computers & Internet
Hal error how do i fix without a backup?
Your Hal or boot.ini files are missing/moved/corrupted. Perform a repair installation of Windows XP. If unsucessful, do a fresh install. Try pressing ALT+F10 during boot to access the recovery partition. This will return your system to the day it was new - yes, all files you have will be lost.
Jun 26, 2010 | Acer Aspire One PC Notebook
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer 5520 restore failed 0xa000000e
I got it to work by deleting all the partitions on my drive (I first loaded xp, loaded system commander 9, and used that to delete all the partitions.)
Then while booting from the recovery cd, holding down alt-f10, the recovery dialog said it was partitioning the drive. (I didn't see this before, even if I partitioned the drive like it came from the factory.)
Then the rest of the recovery worked.
Feb 11, 2009 | Acer Aspire 5520-5908 Notebook
Acer 5100 usb ports,Cam,PCMCIA
This happened to me before - I have an Acer Aspire 5100. I had to take it to Acer (it was under warranty) and they changed the motherboard. Hope this helps =)
Sep 18, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 laptop drivers for xp
there should be all the drivers here, just choose the XP listing and then click the driver you want
Sep 01, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Freezes
I am not sure which you are talking about either. But I will venture to say that I had a similar problem once where setup would not complete on my system either. I initially thought that I had a bad or dirty disc but later after running a few tests, I found out that my HDD was full of bad sectors. Thus I ended up replacing the HDD and all is well. I would try running a stand alone formatting software or you could try doing a complete format vs. a quick format during Windows setup. If setup still won't complete after a complete format then run a surface scan or a HDD regenertion program to verify the integrity of the drive. This will tell you if you have a bad drive or not.
Aug 20, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3680 problem (anyone help plese?)
if you haven't delete the recovery partition, you can reload the OS using alt+F10.
during boot (after acer logo), press alt+F10, it will guide you to reload your OS.
if your recovery partition is corrupt, you should call acer call center to get the cd or you can buy cd from microsoft
Jul 05, 2008 | Acer Aspire 3680 Laptop
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Aspire 5100 problem
You can disable this msg through msconfig or you can restore the os through system tools, if msg is again comming then try to edit the regestry & delete the entry(you can try all this).
Feb 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
