Question about Sony Ericsson Walkman W705 Cell Phone
My fone's MAC address is shown as 00-00-00-00-00-00
Earlier it was working fine. Also some corrosion has come under the SIM contact and the company is saying that water has logged in where as in actually no moisture and water even touched that place.
I have the same problem as you on a G705. I returned it for repair, they updated the software and said everything was working fine. Tried it out... didn't work. Then I got it to work 15 minutes by taking out battery and SIM card a while. Now I'm back with the same problem though... looking for a solution
Posted on Feb 08, 2010
BIOS has been updated. New MAC adress can't be attached to Aus N53SV.
Hello Pan,
As a rule, the MAC address is embedded in the hardware and cannot be changed. It is usually shown on a sticker somewhere on the computer. Are you sure it's not the TCP/IP that has changed? Please post the MAC you're referring to. IP address is in the following form: nnn.nnn.nnn.nnn (example = 192.168.0.1). MAC address example = 00:0a:95:9d:68:16. Let us know.
Roger
Jul 05, 2015 | Computers & Internet
Tip
Linksy WRT54GR Router - Invalid Wireless MAC Address [EN] [FR]
[Englisch]
i have been troubled with the configuration of the linksys router WRT54GR when trying to add my wireless devices to the wireless client table.
First I found following hint:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=46517
then did the following which solved my problem!
I entered the MAC addresses of my wireless devices into the client table and made sure that all remaining entries where not of kind 00:00:00:00:00:00.
Apart from my valid MAC addresses (2 devices) i just had to enter 00:00:00:00:00:03, 00:00:00:00:00:04 and so on! The last entry in my table is
00:00:00:00:00:16.
That's it. Cheers
[French]
Bonjour,
la solution: pour mon problem est la suivante:
Apres les inscriptions des votre adresses MAC vouz entrez dans les lignes qui rester
adresses MAC qui sont different que 00:00:00:00:00:00.
Donc, si vous avez 2 adresses MAC la troisieme sera 00:00:00:00:00:03,
la prochain 00:00:00:00:00:04 .... juste a la dernier 00:00:00:00:00:16.
Voila!
on Aug 28, 2008 | Linksys Wireless-G WRT54GR Router
No signal
It could be either an issue with the phone, or the sim card. Try switching the two to see if the working one still works in the other port. If it doesn't then it's an issue with the sim card itself, and you should contact the company who makes it.
Jul 24, 2013 | Nokia X3-00 Cellular phone - GSM Unlocked...
W1100z - can't turn off 'Wake on LAN' - system
The setting is also in the properties of the network adapter under power management you should be able to just turn it off there by unchecking the boxes.
Apr 15, 2010 | Sun Java W1100z (A58AWB19B512CE) PC...
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
Feb 12, 2010 | Linksys WAG200G Router
Can't find my MAC address
Hi, here is a solution for your problem: Obtaining your MAC address
Your MAC address will normally be on the box or registration card for your computer or individual ethernet card. If you can not find it, please follow the instructions below depending on your operating system.
Windows Vista:
  1. Click on Start Button.
  2. Click on All Programs.
  3. Click on Accessories.
  4. Click on System Tools.
  5. Click on System Information.
  6. Click on plus sign in front of Components.
  7. Click on plus sign in front of Network.
  8. Click on Adapter.
  9. Scroll down to your Network Interface Card and it will list the MAC Addresss. (Make sure you do not get the wireless adapter).
WINDOWS NT, 2000, or XP:
  1. Using your mouse, click on the Start Button.
  2. Click on Programs.
  3. Click on Accessories, and then Command Prompt.
  4. Once a small black window appears, type in ipconfig /all (with a space between the g and the /).
  5. Locate the number to the right of Physical Address. This is your MAC address.
WINDOWS 95/98/ME:
  1. After clicking on the Start Button, click on Run.
  2. In the white space of the window, type in the word winipcfg
  3. Click on "OK".
  4. Look under the info for the Ethernet adapter. (Your system may also have a modem.)
  5. The number next to "Adapter Address" is your MAC address.
Hope this helps.
May 10, 2009 | Computers & Internet
Need a puk code for a i930
The Puk number depends on the pin lock on the sim, the phone will still work with a different Sim card.
To unlock the Puk code you need to call the contact number for the service provider for your Sim. Alternatively you can unlock the PUK code at a local shop for a small fee, £10 or £20 in UK.
To unlock PUK, call the company that branded your Sim card.
For example , f you are in UK, and have lost vodafone or Orange pin, and puk code kicked in, then contact is below.
Vodafone Contact us
Vodafone UK - Contact us
use google to find contact number for your sim card fone company in your area. That is the only way to unlock PUK for free, and it always work.
Mar 03, 2009 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Puk number request
Vodafone Contact us
Mar 03, 2009 | Teac (DV-W58GA-PUK) Burner
Edit MAC Filter List
mac is the address in hex of a network card. To get the mac of a network card: go to command line (windows machine) and type the command ipconfig /all. The mac address is the physical address. It will be in the format of 00-00-00-00-00-00, where the 00's are letters and numbers (hex 0-F) To use this you would take the mac address from your wireless card of your computer and enter this number into the mac address filter table of your router. The idea here is when a computer tries to connect to your router, it looks at the table, if the address in not in the table, no connection. Please remember devices only understand what you give them so a typo is not your device....
Feb 28, 2009 | Gateway Wireless-B Router (wbr-100)
My simcard was block and it was requesting for my puk number.i dont have it and i want to have it now so that my simcard can be re:opened.
Jan 06, 2009 | Teac (DV-W58GA-PUK) Burner
Sony Ericsson Walkman W705 Cell Phone Logo
613 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
