Question about Car Audio & Video
Amp protector light going on and dimming
I hooked up an amp and as soon as i switched on the car the protector light comes on and dims hooked everything up correctly what could be the problem
    President:
  • 846 Answers
first thing you want to check is the fuses in the amp, and power wire if applicable. This might cause the protection light to come on. I do assume you are referring to the protection light on the amp itself and not your car.
Post back if you have checked your fuses and have still not solved the problem.
Thank you for choosing Fixya!
Posted on Oct 03, 2009
My Headlights are so dim that I cant drive at night in my 1997 Chevy Blazer. How Can I get them brighter?
You have to go back to the route cause & time
frame of the problem
Did you check voltage & ground at each lamp connector,
when they first got dim & you started to resolve things?
Why converter to a different bulb?
I don't know the current draw of the oe vs: the H4,but
that has to be considered
Obviously the alternator output would be up there at the
same time your checking lamp connector voltage.
Problem--Voltage Drop somewhere or too much resistance
somewhere,basic OHM's Law
Jan 25, 2013 | 1997 Chevrolet Blazer
Why dimming headlights and interior lights?
The outside lights could possibly be dim because the bulbs are burning out. -----------------------------------------------------------------------------
Renault CAN Clip
Dec 11, 2012 | Cars & Trucks
Dim headlights on 1999 grand marquis
Bulbs -usually burn out, all at once,haven't you had that happen
Blue Bulbs- are illegal in most states & you asked about the most
light. Won't get that from some aftermarket fancy color gimick
So Dim Lights--that is a problem obviously
You will have to have that diagnosed,I won't guess
at it. Only visual inspection & testing will establish why their dim
May 18, 2012 | 1999 Mercury Grand Marquis
Lights dim when bass hits....
you need to upgrade your electrical system.
First easy thing you can do is buy a bigger battery. Get a battery with the highest cold cranking amps(cca) that will fit. Yellow top would be great.
If you have the $$ have a higher amp alternator put in. these are very expensive.
this is an advanced solution, and any vehicle with a big amp should have this done. Its called a big 3 upgrade.
Get some at least 2 awg hook up wire. you will need enough to run a wire to the neg of the battery to the chassis to your altinator. and enough to run from the pos on the bat to the pos on the altinator. and from the neg to the frame of the car.
Use copper lugs and solder them on the ends of the wires. Use a blow torch and pliers to hold it and heat it up. Melt solder into it about half way full, and then push stripped end into it, then squelch it with a damp cloth and wipe it off.
Do this for all, and hook everything up.
You can install a CAP if you want. I personally don't believe in them. They help the car dimming a little, but the lower the voltage at the amp.
Dec 15, 2009 | Jl Audio 500/1 Car Audio Amplifier
I AM INSTALLING A TACHOMETER IN MY 89 MUSTANG GT AND I DONT KNOW WHICH WIRE TO USE ON THE DIMMER SWITCH FOR THE TACH LIGHT?
Grab a $5 12volt test light & probe back of switch where wiring comes into switch, for wire that has power when you pull lights on. If that's when you want it illuminated. If you want it too go bright or dim with dash , poke wires until you find that one, while turning switch to bright dim, and test light will do same.
Jul 05, 2009 | 1989 Ford Mustang
Red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Mar 24, 2009 | Polk Audio PA250.2 Car Audio Amplifier
Tail &.. indicator lights[L.E.D.] are constantly flickering dimly, even tho lights are turned off .Starts soon as ignition switch is turned on.
This sounds like a earth problem. Have your earth connections cleaned and checked. You may need to replace your rear light bulb holders.
Sep 29, 2008 | Volkswagen Touareg Cars & Trucks
Sony Xplod 1200w
Either the speaker is shorted out (blown), or the output transistors in the amplifier are bad. Try hooking up another speaker to the amp. If it plays, the amp is good. If not, then the amp is bad.
May 22, 2008 | Sony XM-1252GTR Car Audio Amplifier
Car Audio & Video Logo
161 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
