Question about Toshiba Satellite A100-S8111TD Notebook
How to enable my bluetooth on my toshiba laptop
  • Anonymous Mar 16, 2014
    enable bluetooth on toshiba laptop
    Scholar:
  • 83 Answers
Most of the time when you go to Start - All Programs - Toshiba you will see Bluetooth. This will be there if you have the driver installed. Also, make sure that the Bluetooth logo is on the bottom of the laptop to make sure that your model was built with the Bluetooth chip in it. Sometimes you can also find the bluetooth icon on your taskbar and by right clicking on it you will bring up the "enable" option. You may also want to go into your control panel and see if the icon is in there. The shortcut to get to the control panel is "Start" key then press the "c" key. Hope this helps.
Posted on Oct 07, 2009
    Scholar:
  • 135 Answers
Check if you have the hardware first under device manager>bluetooth. Make sure that it is a device. If yes, you may need to turn on your wifi switch on your laptop and it should show you the BT Icon on system tray.
Hope this helps
Posted on Oct 03, 2009
3 Suggested Answers
damneddle
  • 1607 Answers
SOURCE: how do i enable bluetooth in Toshiba laptop
Hello angel,
You can enable and disable Bluetooth by pressing Fn + F8 (Press and HOLD Fn key and while still holding the Fn key press F8 key). You might need to press it repeatedly until you see the Bluetooth is ON.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Posted on Oct 14, 2011
Rautela
  • 24 Answers
SOURCE: how to enable bluetooth on hp pavillion laptop
Hey there,
If your particular model of HP has the bluetooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the bluetooth, as well as the wireless LAN. A bluetooth icon should appear in your taskbar, near the clock, when bluetooth is turned on. Most of the cheaper versions of the DV6000 series do not come with the bluetooth module installed. The module can be ordered from HP Parts and installed by the end user, if they have a little computer know how. You would then download and install the bluetooth software pack that is available on HP's support website.
Hope this will help to resolve your issue with Bluethooth..
Cheers!!!!!
Vivek
Posted on Feb 14, 2010
A665-s6094
Yes and no...Yes, you can add this module:
  • Part Number PA3710U-1BTM
  • Description: Toshiba Bluetooth 2.1+EDR USB Nano Adapter
This will enable bluetooth functionality...There are drivers for the bluetooth stack on the support website:
Satellite A665 S6094 Support Toshiba
But no, bluetooth is not built in...
May 25, 2014 | Toshiba Satellite A135 Notebook
Satellite c55-a5308 bluetooth enable
search for switch or button to activate wireless on your device. Have you verified that the Bluetooth radio is turned on? If the radio is off, then nothing may show in Device Manager. Look under Network Cards - unless your BT radio exposes a PAN (personal area network), you won't find anything there. You need to look under the "Bluetooth Radios" section.
Jan 17, 2014 | Toshiba Satellite A135-S4527 Notebook
Enable bluetooth on c55-a5308 satellite
On the laptop you should fine a way to enable blue-tooth. usually there is a button close to the power button across the top. Alternately, you can do so from control panel too.First you need WinXP SP2 or higher version of OS.Go into the control panel, double click on bluetooth, in there, there is a setting for "Turn Discovery On". Put a tick in that box and then try pairing the laptop with any other device
Jan 17, 2014 | Toshiba Satellite Computers & Internet
Enable Bluetooth on Toshiba
Please check the driver and also check if there is a software to assist enabling your Toshiba bluetooth (certain model) here:
http://support.toshiba.com/drivers
Dec 25, 2013 | Toshiba Computers & Internet
How do i enable bluetooth in Toshiba laptop c660-1TE
Hello angel,
Thanks!
-damneddle
Oct 14, 2011 | Computers & Internet
I have a toshiba l755d, how do you use the bluetooth
is your laptop Bluetooth ready or is it Bluetooth enabled?
To find out if it is Bluetooth ready go to control panel and see if you can see a Bluetooth icon anywhere if you have then just click the Bluetooth icon and it will take you through a setup wizard to connect to your phone or any Bluetooth device.
If it's not there then your laptop is most likely Bluetooth ready which means it can support Bluetooth, so you will have to buy a Bluetooth adapter which are fairly cheap.
hope this helps.
Jul 16, 2011 | Toshiba Satellite L500 Series Notebook
Bluetooth config
You can enable it by hitting your windows button on the bottom left of your keyboard and then hitting control panel. From there, go the the blue icon that says bluetooth.
Sep 21, 2009 | Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Hi!i have a toshiba satellite A135-S4527 laptop but i don't know if it has bluetooth or not.
There should be a bluetooth key on the on the keyboard to enable it. If there isn't one, check for bluetooth drivers in the control panel to see how to enable it or to verify the hardware.
Aug 06, 2008 | Computers & Internet
Blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Jun 14, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
2,340 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
