Question about Kicker KX400.1 Car Audio Amplifier
Amp not powering at all
I recently got a Kicker KX400.1 from my cousin and when I hooked it up just to the battery, there was nothing lit. No power or protection. What can be done about this
No electricity
Posted on Jan 21, 2008
  • 631 Answers
Did you apply 12v to both the B+ terminal and the remote terminal?
Did you check the fuses?
Posted on Dec 21, 2007
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
Why does my amp turn off when i hook up my 12 inch kicker
Possibly due to a poor battery, you could try installing a power cap to prevent the amp shutting down/protect due to low voltage when the starter kicks in.
May 10, 2012 | Kicker 07CVT124 12 inch ShallowMount...
I have an AudioBahn A4004T Amp. It was working fine and then I had it sitting in my house for a few months. My cousin wants to use it in his car so he hooked the power cables up to his battery to see if it...
If you only hooked up the power and ground the amp will not turn on. You must also hook up the remote wire. This either can come from your radio, your fuses, or your power wire itself. If you hook it up to your radio then it will turn on when the radio is turned on. If your radio doesn't have a remote wire to amp then you can read your owners manual and hook it up to the radio fuse and when the radio turns on the amp will turn on. An lastly you can run a wore from your power wire to your remote plug in. But if you do this the nano will constantly be on if it is hooked up to the battery.
Dec 25, 2010 | AudioBahn A4004T Car Audio Amplifier
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
I have a 1000.1 kicker amp and when i have the amp
you might not have the battery power to power it or it might not be the right ohms. i just had this happen to me after i hooked up 4 cvrs to the same amp. today it just quit.i got to get it checked out to see if i blew it.
Nov 22, 2009 | Kicker ZX10001 Car Audio Amplifier
My Kicker 04KX400.1 stopped working. Checked fuses/cables. Plz help!
Hello dbarlow_it,
You do not say if the amp is showing an indication of powering up or not. If it is getting power, the "power" LED should be lit.
There's also an inline main power fuse that should be located within a foot or two of the positive battery terminal. If you have checked it also and it's good, test for 12V+ at the amp power terminal. If you are getting power, then check that the remote turn-on lead is still functioning. It should also have 12V+ on it when the receiver/head unit is turned on.
If the amp is getting power, and a turn-on signal from the remote, it's most likely that the amp itself is defective.
Hope this helps.
Aug 13, 2009 | Kicker Car Audio & Video
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker zx1500.1: no sound output
Does it make the same noise if the RCA cables aren't plugged in?
Apr 10, 2008 | Kicker ZX10001 Car Audio Amplifier
Kicker amplifier
Sounds like you popped a fuse my man. Check your Manual on how to replace them.
Feb 11, 2008 | Kicker KX600.1 Car Audio Amplifier
Kicker KX400.1 Car Audio Amplifier Logo
75 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
