Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My ryobi 30cc 3043 idles but when i accelerate it snuffs out I have cleaned the carby and it still cuts out
  • 245 Answers
Sounds like the high-speed gas mixture is too lean. When you cleaned the carburetor did you use compressed air to clean the tiny fuel passages? If you are confident that the fuel passages are clean, and that there is no gunk at the tip of the fuel adjustment screws, you may be able to adjust the screws to solve the problem. You might try gradually increasing RPMs by goosing the throttle repeatedly, letting off all the way in between each pull so it won't stall. If that works it indicates you can probably fix it with an adjustment. When you cleaned the carb you should have counted how many turns it took to screw in the fuel/air screws all the way, then removed them to blow out the fuel passages with compressed air. That way you would know how to replace them correctly.
Posted on Oct 03, 2009
Repair video on removing cylinder from a ryobi power head.
Ryobi Technical Support Questions - HelpOwl.com
https://www.helpowl.com/Ryobi/Technical-Support
Ryobi - How Do I Replace A Piston On My Ryobi Edger. Ry 34006? ... Ryobi - Just Bought The Ryobi 30cc 4-cycle Power Head
Apr 26, 2015 | Ryobi Garden
Will not excelerate past 4000 rpm
IF you have a carby then take it apart and clean it out as all the throats are not working properly including the accelerator pump.
Apr 06, 2014 | 1986 Toyota Celica
Two stroke weedeater starts,idles, but boggs down when gas is applied. it won't reach top end speed.
have a look on side of carby should see 3 small screws a high and a low idle screw , when running unsrew the high idle srew slightly and it should fix
Sep 18, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Needs carby ajusting for ryobi lawn hornet 70 about 15 years old but has been great
Hi duthie20, the low speed(closest to engine block) should be 1 and a quarter the high speed 1 and a half(the other one). That should get ya going, you may have to tweek these adjustments a little eigther way. Happy New Year!
Dec 28, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
Oct 19, 2008 | Garden
Ryobi petrol 30cc Trimmer plt 3043 ye
Hi! With the red know in one hand, push the spool down with th other to the female threaded shaft comes to the top. Then, hold the red know in the other hand with your index finger on the bolt in the middle, holding it down. Now start threading it onto the female shaft COUNTERCLOCKWISE! Once you get it, it get's easier. Good Luck!~Frank~
Jun 07, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
566 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
