Question about Logitech 9312210403 Mouse
The mouse left click
The left click will not work on links....or when I try to check a box you have to right click and press open link but it works for everything else...and when I do click with the left it does change the color and show the web page in the lower left corner of the screen...
SOURCE: Wireless Mouse gets stuck
Take a eraser and use it to rub the contact points on your batteries clean. This seems to be the issue where your sensiativity will change by it self the the mouse has a 20 - 30 pause to reset it's self as if you just stuck a different battery in it.
Posted on Jan 13, 2008
  • 148 Answers
SOURCE: Logitech MX610 problem.
best thing to do is to replace your mouse
Posted on Mar 23, 2008
  • 63 Answers
SOURCE: I have a g5 logitech mouse
I had the same mouse, and the exact same problem happened to me, in the middle of Half Life 2, only 5 months after buying it.
Unfortunately I had lost my receipt. If you still have the reciept or proof of purchase, Logitech does have a 1 year manufacturer's warranty. You may want to send it to Logitech and get a replacement.
You can try to open the mouse up and see if you can find the component that doesn't allow the right click to work anymore, but it may be difficult to open, and if you are within the 1 year warranty, opening it up will void that warranty. I remember taking a look at it and from my memory there is no screws holding the mouse together and would be a hassle trying to crack it open and try to fix the button. I ended up just going to the store and purchasing a new mouse.
Posted on Apr 08, 2009
  • 4806 Answers
SOURCE: LX7 Cordless Optical Mouse troubleshooting
Hi there.
Go to the control panel, in control panel you will see mouse, click on that and you will be able to set reaction times speed click times and all the mouse settings.
Good luck and thanks for using FixYa!!
Posted on May 28, 2009
  • 1498 Answers
SOURCE: Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Posted on Jul 29, 2010
SOURCE: right button doesn't work; single click with left button
left button doesn't work; single click with left button
Posted on Nov 01, 2010
0 characters
1 Points
Left button does not always open link/menu box options, I have to right click to open menu box and then left click the 'open link' option, please help.
That's not abnormal; some links provide primary drop-down choices when you place your cursor on them and enable you to select a choice by left-clicking on one of the choices. Others only enable you to select certain actions by right-clicking to see a drop-down list.
Feb 03, 2011 | Logitech LX5 Cordless Optical Mouse
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
I just got a new mouse, and last night when I
try to do these things:
1. press the black link button on your puck or key that connects to the PC usb port.
2. turn the only switch on the bottom to ON (to the right)
3. press the link button on your mouse on the underside.
4. double left click your mouse to make sure it will wake up and run
5. check it on another USB port
6. look for damaged pins in your usb port on the laptop
Sep 24, 2009 | GE Wireless Optical Mouse
Mouse wont work. can right and left click but can't control the cursor. using a net book by dell with microsoft xp
Go to control panel click on mouse icon and look for open new page or link when mouse hovers over top it. and make sure the box is unchecked and i think that should fix it that sounds like that is what your problem is.
Aug 12, 2009 | Keyboards & Mice
Mouse stopped working..changed the batteries..was working, now it
There should be a connect button on the receiver either on the top or underneath, if there is press that button.
Then go to the mouse and press the connect button on that and just left or right click to activate it.
Let me know how you get on or if you need any more help.
Good luck
Jun 01, 2009 | GE Wireless Optical Mouse
My Logitech cordless mouse MX 700 is being eratic.
There could be a sensitivity problem with the mouse before installing new drivers and software you can try going to the mouse settings to see if there's an adjutment problem,
  • click on the mouse icon in the control panel
  • a mouse properties box will pop up
  • at the top of the box click hardware
  • look to see if your mouse is labeled under devices.
  • highlight your mouse it should say, this device is working properly.
  • you might want to go through all the mouse settings first to make sure there set right, pointer's activities, pointer option's, ect, if your still having problem's here's a link with the software and driver download for your mouse,,en?prodcrid=398
also replace the battery if it's low, good luck.
Mar 30, 2009 | Logitech Cordless EX 100 Mouse
Logitech downloads for V220 logitech mouse
You can get it HERE. Choose the correct operating system to download your driver.
Jun 21, 2008 | Logitech Cordless Mouse
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
Logitech 9312210403 Mouse Logo
18 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
