Question about Hifonics BXI2608D Car Amp
This amp doesn't have fuses. Do I need an inline fuse on the power wire befrore I hook it up?
Connecting mtx fex10a-tn subwoofer to sony xav601bt
You should always wire your amp directly to your battery. and an inline fuse of about 100 amp. about 3-5 feet from the battery.
Dec 15, 2012 | MTX Audio Thunderform FEX10A-TN Black,...
Amp doesn't receive power
check inline fuse on power wire, or fuses on amp itself
Oct 18, 2012 | Boss CHAOS CH450 Car Audio Amplifier
Radio shack cb radio trc-481 model no.:21-1550b. i need to know to hook up the wires to my truck
Red wire is the primary power, this can be hooked to a fuse in the fuse block that shuts off with the vehicle, such as the fan or windshield wipers, the white wire is the memory power, this should be hooked up to either the battery (not recommended as you will pick up alot of engine noise), or another fuse that has a constant flow of power...such as interior lights. Not that both red & white have an inline fuse of there own, anything over 2amps will cook the radio.
If interested in operating without the vehicle running, hook both to a fuse in the fuse panel that has a constant power flow, use the same fuse for both red & white, not going over 3amps MAX!
Black of course, is your ground.
*NOTE-any many radios, the better the ground, the less engine noise your radio will pickup, because alot will be flitered through to the ground. Best to run it to the body, for example the bolts that attach your seat to the body...put the wire between the bolt & the floor...this helps create a capacitor like ground.
Citizen's Band Central~Find us on facebook
Sep 18, 2011 | GPS
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
The Red & Black wires connected to my AMP touched
You blew the inline fuse on the AMP power wire. If it was not fused "inline" you may have blown a fuse internal to the amp. Look on the amp(or consult the manual) for the location of fuses "internal" to the amp.
May 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
Will not power
Yeah my guess without seeing it is that you did fry your amp. You really need to hook up two fuses inline on your power feed; one no farther than 18" from you battery and one inline at you amp.
Jun 25, 2008 | Rockford Fosgate Punch 301S Car Audio...
Amp issue
rca cables and connectors
Aug 16, 2007 | Orion 3002 Car Audio Amplifier
Hifonics BXI2608D Car Amp Logo
37 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
