I'm trying to change an ink cartridge. Cartridges
I'm trying to change an ink cartridge. Cartridges don't stay visible - they hide away to the left or right of the printer. How do I get them to stay in the middle/visible?
Thanks.
  • 245 Answers
Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
Posted on Oct 03, 2009
Testimonial: "Switched printer on/off. Made no difference. Will google make and model as you suggest. Thanks."
Kodak esp 7250 printhead carriage jam
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Mar 09, 2013 | Office Equipment & Supplies
'Left cartridge incorrect' error message. Have tried changing the cartridge, cleaning the cartridge, running a flush cartridge etc but will not recognise the cartridge and so will not print. is it...
These printers monitor the cartridges and dont like you using aftermarket ie non Lexmark, or not made by lexmark cartridges. So Im wondering If you have tried 2 x brand spanking new OEM Lexmark cartridges, or if you are trying to use cheaper from net remanufactured or "for use in lexmark" cartridges. If this is the case then this is your problem and also very common.
Are you using a photo cartridge and a normal color one?
These I beleive can not be mixed in different slots.
- Photo cartridges you will only need one installed on the left side.
- Normal ink you will need two installed (Black on left and color on right) .
Also Lexmark themselves have a couple of documents on this issue, here and Here
But these efforts will all be useless unless you are using Brand New Original Equipment Manufactured (OEM) Cartridges. This I see day in and day out, I get a lot of people tell me they are using original when they are not in fact, You will know by the price and lexmark carts do not state "for use in"
I dont think it is a problem with the printer, if you are using both brand new OEM cartridges then the firmware fix from lexmark should solve or you are trying to mix Photo type and normal type carts.
But these days ink jet printers are non repairable (well too costly and uneconomical to repair) throw away items, the expense is in the inks and manufactures vertually give away the printers so you will buy their inks, and lexmarks are designed not to like refill and aftermarket inks as are most modern inkjets.
Hope this helps, please let me know if you are using real ink and have tried the firmware fix and still are having issues, but all i probally end up telling you is buy another and welcome to our disposable way of life;)
Regards
Steve
Feb 21, 2012 | Lexmark X4550 Multifunction Wireless Color...
Kodak 7250 print head jam
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Hi. After using budget ink cartridges, the print quality has been very poor and not printing the correct colours it suppose to. I've performed many print cleaning options but it is still not rectifying...
If the cartridges you're using give you poor results, throw them away cos you don't know what other damage they might be doing.
I'm not saying don't use budget cartridges, just bin them if they don't work properly and get a different brand.
Alternatively, are cheap cartridges worth all this hassle?
May 30, 2011 | Brother MFC 6490CW InkJet Printer
Black no longer works on my HP Photosmart 3210. Have tried: - Running the cleaning program many times. - Changing the cartridge. If it was just a printer, I'd throw it away, but it is also my scanner and...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 22, 2010 | Office Equipment & Supplies
Printer will not print...when I review the computer setting it states OFF LINE
Did you recently Chang the ink cartridges? Are you using factory new Brother ink cartridges instead of third party ink and cartridges or refilled cartridges?
Some companies use logic in the printer to prevent after market ink and cartridges from doing damage to the printer because of contaminated or sub-standard ink.
Don
Dec 14, 2009 | Brother HL 1440 Laser Printer
Still showing Empty even with new colour cartridge
This is a common problem mostly associated with but not confined to compatible cartridges where the chip on the cartridge is faulty, missing or is not making contact correctly with the printer cartridge connectors. The first thing to do is make sure that the plastic seal has been removed from the chip and that it is free of any residual adhesive etc. You can clean this with a cotton bud soaked in isopropyl alcohol or VCR tape head cleaner. DO NOT USE SURGICAL SPIRIT or any other cleanser as this will either leave a residue itself or damage the plastics and rubbers in the printer. Also do this around the port where the ink exits the cartridge to wipe away any accumulated ink residue.
Once cleaned, making sure that the cartridge is dry of any cleaning fluid, reinsert the cartridge and try again. Make sure that the cartridge is seated correctly and locked down.
Then run a printer cleaning cycle, then test print, then the alignment cycle and if necessary a deep cleaning cycle then test print and realignment cycle.
If this is still unsuccessful the best solution is to return the cartridges to the vendor where you bought them and get another brand of cartridges or use genuine original cartridges. When you find a reliable manufacturer of cartridges, stay with them. Don’t forget to clean the print head and realign & recalibrate the printer at every cartridge change for optimum results. Also make sure that you use high quality paper for the best images results.
You could try running a cleaning cartridge through the system or buying a newly available Chip reset module available from most ink resellers. If these are not an option then you are possibly looking at buying a new head assembly.
Some other options that may work. Open the cover, remove the cartridge, tilt the whole printer forward away from you about 45 degrees, reseat the cartridge and close the cover.
This has worked for me several people. I think there is a small sensor behind the contact chip that detects ink levels and when my printer is flat the level of ink is lower than the sensor, when I tilt the printer the error vanishes because the ink covers the sensor. Though I am not sure why the software in the printer determines that there are duplicate cartridges instead of just a low ink warning.
You can also lightly lift the prongs that contact the chip that are inside the cartridge carrier wit a pair of needle nosed pliers, a needle or dressmaking pin, They do bend easily so be careful Then reseat the cartridge.
Nov 11, 2009 | HP PSC 1410 All-In-One InkJet Printer
How do I manually center the ink cartridges on my A960 ?
The ink cartridge had jammed the carrier and prevented it from moving. I stuck my little finger in the bottom of the carrier, pushed the cartridge up a bit, freed the carrier and was able to move it manually. I replaced the cartridge and all the messages went away. The printer now works as it should. Must have been a bad cartridge.
Nov 10, 2008 | Dell A960 All-In-One InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Inserting the ink cartridges!
I read one of the earlier posts which helped; the problem was that there is a dock built in to the left, but that is NOT where the ink goes! The real place hides to the right and only slides over when the printer is turned on. I had to almost force it to get it to stay to the left over the dock so I could actually insert the ink cartridge. The previous posters' soluntion, turning the printer on so the cartridge dock moves into view, is the only thing that worked for me.
Feb 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
61 people viewed this question
jasbo
jasbo
