Question about Symphonic Televison & Video
I have a 27" Symphonic tv. I don't know the model number but it looks a lot like the ST423E one. It has the exact remote too. I was wondering if there's a way to us the A/V plug ins in both the front and back of the tv. We can use the from one and it works in Game mode but I don't know how to access the ones in the back. We've just been unplugging the A/V cords in the front and using that for everything but it's getting annoying. I do have cable too so I'm not sure if that affects anything.
SOURCE: Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I have the same TV & problem.
The problem is Not with the remote but with the remote receiving circuit in the TV. The remote works once in a while.
Anyone have the TV schematic diagram?
Posted on Apr 28, 2008
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
i bought tv ,just week ago and tv sensor on tv want wwork, that why we cant use remote.
Posted on Oct 09, 2008
SOURCE: How do i get my symphonic tv into video mode without remote?
Hi Guys
This will help you a looooot
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 16, 2009
SgtScagnetti
  • 16 Answers
SOURCE: how to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
Posted on Dec 27, 2009
SOURCE: Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Posted on Jan 03, 2010
I have a symphonic 27 inch tv and need the code
Google the model number of remote and the set for "manual" which should have possible codes.
With the manual for the remote look to see if it has a search mode which will allow you to try every possible code one at a time to find one that works.
Universals even if programmed will be missing key features the original remote had.
Apr 23, 2012 | Symphonic wf27f4 27 inch Flat panel TV
Remote
Is this the original tv remote? What exactly do you need to reprogram?
Thanks,
Lee
Sep 01, 2008 | Toshiba 27A44 27" TV
Find code for symphonic tv remote
very few if any universal remotes will work on Symphonic which is also Funai and some other brands.
Look on Ebay or Google the model number of the set with the word remote, remember not a universal.
Mar 10, 2012 | Symphonic SC313D 13 in. TV/VCR Combo
I have a Gemini remote and a Symphonic TV (model # WF20L6) and am wondering what the code is? The remote only says Gemini on it. Help !!
Hello
Without knowing the exact model number of the remote, it will be difficult to locate the codes. Anyway, try thesed codes.
033/ 053/ 189
If your TV needs a four digit setup codes, you can try these codes.
0053 0189 0227 0456 0024
OK
Oct 23, 2011 | Gemini 1 Device Universal Television...
What is the ge universal remote code for a symphonic tv?
You need to supply the exact make and model of the TV and the model number of the GE remote. The code cannot be determined without this information.
Thanks.
Jan 02, 2010 | GE Televison & Video
What is the remote model number for a Symphonic tv/vcr model #SC309C? Also for a tv/vcr SC3909 and tv/vcr TVCR9G1 ? I'm trying to figure out if I have the correct remotes for these tv's. Thank you
Funai manufatures all Symphonic products:
Remote for SC309C = Funai Part Number: N0150UD
Remote for SC3909 = Funai Part Number: N0258UD
Remote for TVCR9G1 = Funai Part Number: N0200UD
Hope this helps!
Triron72
Mar 26, 2009 | Televison & Video
Codes for tv
usually the universal remote comes with a code book. if you're TV is not on it the remote won't work. But most TV's are on there. If you can't find the TV, go to the ORIGINAL COMPANY of the TV. (RCA, Samsung, etc.)
Jul 03, 2008 | Symphonic ST419E TV
ST423E SYMPHONIC 23 TV 2.1
set is shutting down. most likely in high voltage circuit feeding back to the power on rely.
May 26, 2008 | Televison & Video
Symphonic b-19wm
It can be the remote sensor, or the circuitry that works with it. I don't know its exact location for your model, but you can usualy find it, because at its location it looks like a little black or dark red window in front of it.
The sensor and its related circuitry are servicable. To find the exact fault will require using a DVM and an oscilloscope to trace down where the signal is stopping from the sensor. The sensor feeds the main uPC controler via a number of components on the circuit board. An experienced service tech should be able to troubleshoot this for you, and replace the defective parts. On rare occasions the fault can be with the uPC itself.
It is also possible that there is a cold solder connection on the circuit board that is stopping the remote sensor from getting the remote signals to the uPC.
Jerry G.
Apr 11, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Remotes quit working
Take your Tv to the Technician to check for you if the sensor is working properly.
Mar 24, 2008 | Symphonic ST419E TV
Televison & Video Logo
64 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
