Question about Dewalt Saws
Dewalt bench saw
How do i change the direction of rotation of the saw blade
  • David Ford
    David Ford May 11, 2010
    Do you mean the saw is running backwards or are you trying to cut vinyl siding or something similar, there is a difference.
    Novelist:
  • 141 Answers
All electric motors are set up in the same way. (Please refer to the little schematic I have drawn below.) Different models are wired slightly different and please note that your particular saw may only be able to go in one direction. Also some fields have 4 wires instead of 2, and if this is your case please ignore the rest of this post and bring your saw to a professional to be looked at. If your saw is going the wrong way your motor may be damaged and will need to be replaced or at least tested with the proper equipment. With that said, there should be 2 wires coming from your field. Wires "B" and "C" respectively. One of these should go to your switch, and the other should go to one of the brushes. Wires "A" and "D" are coming from your brushes and as noted above one should be going to the field. Let's assume that wire "A" is directly hooked up to the white wire of the cord. And let's also assume the the black is hooked up to "C" of the field. "B" and "D" should be linked in this setup. In order to reverse the polarity of the motor you would switch the field brush setup. One field wire and brush wire should always be connected to complete the circuit. By changing the "B"-"D" connection to instead be a "C"-"D" connection with "A" still going to the neutral "white" wire and now the "B" wire going to the switch, you have effectively changed the polarity of the motor. ****Please note that some of these saws have an electric brake and should not be rewired in this manner**** Again if your saw just started going the wrong way one day, you should get it looked at by a professional repairer. There may be more problems that have caused this to happen,
Posted on Oct 07, 2009
My DeWalt saw starts then stops, like something overheats. ???
Belt drive or direct drive? Sounds like a bad bearing. Some of the DeWalt products are total garbage (we had a brand new bench grinder that was junk from day one).
Jan 06, 2018 | Dewalt Saws
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
Can't rotate the blade carriage.
I guess that you are releasing the handle for the tilt? When released does it feel like it did? Does the carriage move any? What I would do is unplug the saw and put it on a workbench or floor and carefully tilt the saw on its back edge, holding the guard to keep if from falling quickly. Look under the saw for a bent rail and if not try to push the saw tilt by hand pushing on the bottom guard. You might have to lubricate the slide underneath or loosen up the locking mechanism. If you need a copy of the owners manual I would go to Dewaltservicenet.com and typing in your model number to download it. I really don't think it is anything major. Let me know
Jan 15, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
504 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
