How can i remove a screw with an interlock???? I need to replace the lamp in my hitachi rear projector t.v.
  • 115 Answers
Unplug the tv .then remove screw-> lamp door -> lamp..Interlock is going to be a swicth engaged by the lamp door that is supose to disable the parts that might give you owies when replacing the lamp. (incase you don't uplugg the tv first). ALSO you must to put the lamp door back on after replacing the lamp.(or else Mr. interlock switch won't let the tv turn on )
Posted on Oct 03, 2009
Light bulb replacement
https://www.google.co.uk/search?q=Hitachi+CP-X253+bulb+replacement.
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Jan 30, 2014 | Hitachi CP-X253 Projector
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
How do I change a bulb in a Hitachi CP-S210 Multimedia LCD projector?
There will be a panel that holds the lamp module in, usually on the base of the unit. Once removed the lamp is usually held in with two screws mounted on the body of the lam. Once replaced, ensure the lamp is correctly fitted and the panel then switch on and reset the lamp life in the settings menu.
Good luck, hope I was of help to you
Aug 04, 2011 | Hitachi CP-S210 Multimedia Projector
HOW DO i REMOVE THE BULB FROM MY HITACHI CPX200 PROJECTOR
remove the lamp cover, loosen the screws, and pull the lamp out using the spring handle.
Jun 17, 2011 | Hitachi CP-X200 LCD Projector
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
We have a hitachi cpx260 projector. both the power light and the lamp light is red.
This usually means you need to replace the lamp.
1) To do this, power off the machine and disconnect the power cable.
2) Open the lamp compartment, and remove the lamp. You'll need a screwdriver for this. I recommend having both a flat-head and phillips-head as the screw on the compartment door and the screw holding the lamp in are not always the same type.
3) Replace with new lamp and fasten with screw.
4) Reattach lamp compartment door and fasten with screw.
5) Power on your projector and go into your menu.
6) Find the lamp timer setting and reset the timer to zero.
Oct 18, 2010 | Hitachi CP-X260 LCD Projector
How to remove lamp of epson projector emp-82
the top of the projector back left hand corner facing the lens. there is a panel door there is a screw located on the rear of the unit that holds the lamp cover. remove this screw then slide and lift up on the panel door. As you look inside you will see two lamp screw that need to be removed as well. hold the lamp and lift it up out of the projector. Insert the new lamp and replace the screw.
You will then need to reset the lamp hours in configuration menu. This is a good time to clean your filter this is located on the bottom of the projector near the front.
Jun 08, 2010 | Epson EMP-82 LCD Projector
Green projection lamp not working
  1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
  2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
  3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
  4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
  5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
  6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
  7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
Nov 03, 2009 | RCA P52939 52" Rear Projection Television
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
How to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Dec 04, 2007 | Office Equipment & Supplies
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
