Question about Pen Drive IVO MP3 Player
Not getting the pendrive listed in device management list...
I am not even getting the pendrive listed in the list of disk management....what should i do ?
  • 2,386 Answers
Try on other computer it might infected by virus, otherwise it may gone bad.
rate the solution plz...
Posted on Oct 03, 2009
Contaess transcend pen drive
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Jul 18, 2013 | Electronics - Others
Hai this is krishna . i have 4 gb kingstron pendrive . it shows used space 0 bytes, total 0 bytes its shows error while copy the data to this pendrive. i am trying to format it, but it will not...
It sounds like your pendrive file allocation is faulty. You need to build one for it. Try to use FDISK utility. Follow below steps to find the tools using windows :
To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Topor Bottom on the View menu, and then click the view that you want to use.
Please make sure you are working on your pendrive drive letter. or else you will corrupt your HDD partition. on the tool, right on your pendrive letter and select create partition and follow the wizard.
Good luck ;)
Mar 01, 2011 | Computers & Internet
My pendrive is 8gb kingston pendrive but it shows only 1.96 gb on computer. give me an advice to fix it pls...........
Check if you have a partition on the drive. Open my computer and see how many HDDs are showing if it only lists your pen at 1.9gb and no other drives apart from the OS drive you may have a hidden partition.
Right click my computer and click on manage this will bring up disk management see how many drives are listed apart from the primary drive (C normally).
I can talk you through the steps of deleting a partition however you would lose all the material on that partition.
If you did find a hidden partition in disk management you can copy the material to the desktop then delete the partition.
Have a look and let me know.
Hope this helps.
Aug 18, 2010 | Computers & Internet
My pendrive cant format
ok
Open control panel,
Then administrative tools, then
Then computer management,
Then in the left column select disk management.
All the disk will be populated in the list below.
Then select the pendrive and format with file system desired.
Thank you.
uttam
Jun 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4G Usb Imation Pen Drive has stopped being picked by any PC
there are two reason for ur problem
a) when windows XP fails to allocate a drive letter to your portable drive(pen drive)
b)some other technical faults in your pendrive
to solve ur problem follow these steps below
Right click on My computer icon->Select manage->Select Computer management->Select Disk Management under the storage section
-> In the right side will show you all of the current drives and partitions on your drive.
If you don’t know which is your pendrive, don’t worry, just find the drive you are looking for in the graphs at the bottom. They are usually named Disk 0, Disk 1, CD-ROM, CD-ROM1, etc.
If you’re looking for a USB flash drive, you’ll see the word “Removable” underneath Disk X -> Now right click on the icon -> Select Change drive letter and paths -> Assign a new Drive letter-> click Ok.
Now your pen drive will be detected in the computer.
there is an another way to solve ur problem
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, i think this should solve the problem.
May 12, 2010 | Computers & Internet
When i insert my pendrive its coming that device
DID you tried different USB ports?
IF YOU DNT NEED the inside data you can always format it.
..using any usb format tool (DriveKey), or u can even go to administartor tools, device managment, disk managment, locate your flashdrive and format, it will be back to normal state after that.
Jan 01, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb stick is not working. the computer sees it but its not accessible and i windows cannot format it.
Does it appear as a drive letter? If not, try to go to Computer Management (in XP right click on MyComputer and choose Manage, on other versions you have to find it yourself), open Disk Management, find a disk without a drive letter, with a capacity that matches your pendrive, and assign a drive letter to it, one that's not used. A good idea is to use letters towards the end of the alphabet. Once you do it, the pendrive should appear on the list of drives in My Computer.
Oct 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Transcend pendrive
you just uninstall that unkown device which you get in device manager and reconnect the pendrive if again it says unknown device then goto update driver and select 2nd option which is advanced in that select don't search for driver i'll select and select the driver which is shown in the list and click next and finish ur pendrive will works
Jul 08, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
Jul 23, 2008 | Transcend (589307) Media
Pen Drive IVO MP3 Player Logo
100 people viewed this question
Top Pen Drive Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Computer Links
Michael Galve
Michael Galve
Are you a Pen Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
