Question about Numark Avm02 Audio/Video Mixer with Effects
Did not get a manual do not know how to set it up
    Scholar:
  • 90 Answers
You can download the manual here:
http://www.numark.com/contentmgr/showdetails.php/id/1147/tt/5
Posted on Oct 03, 2009
Hi, i can't get an even output when i try to use stereo channels. One channel is still very loud and the other very weak.
Please read page 63 of your user manual. The key word here is "PAN" under thee "MAIN VOICE" which controls the balance between left and right. I know that the user manuals are often like reading a foreign language, but they are often the only method we have to learn about the thousands of settings in these synths...
Mar 07, 2011 | Yamaha MM6 61Key Synthesizer Keyboard
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
I need to know if the speakers on the Korg PA588 keyboard cut off when the line out is plugged in or if they stay active. Thanks!
Here's a link to the downloadable manuals:http://www.korgpa.com/pa_root/en/products/pa588_man.html?en From reading the quick start manual the impression I got was the speakers stay on but for private playing, the speakers cut out when the headphones are plugged in. This is the way most keyboards are set up. Let me know if this helped.
Jan 25, 2010 | Korg Pa800 Synthesizer
Don't need a repair. I need a manual. know where I
Line 6 has the manuals on their site.
The Spider III 15 is in two parts: part 1 and part 2
The first is the manual, the second is the sample settings.
Both are PDF files.
Jan 20, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Does it have the option to load other sounds in it?
Here is the manual if you don't have it:http://www2.yamaha.co.jp/manual/pdf/emi/english/ssdrums/dtxp4_en_om_d0.pdf The set comes with 427 drum/percussion voices and 22 keyboard voices. If you use a midi cable plugged into the midi out on the sound module you can control other midi sound modules and midi devices by plugging into the midi in on them. Page 30 of the manual describes some of the parameters. If this helps please let me know.
Nov 19, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Unit will not turn on. I think it was stored in a car for a while and do not know anything about this unit.
Try here:http://www.yamaha.co.jp/manual/english/result.php for the manual. Try here for advice:http://www.yamaha.com/yamahavgn/CDA/ContentDetail/Text_WithCatMenu_SC.html?CTID=410055#opt3
Oct 16, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
Aug 16, 2009 | Music
Bought a used dtxpress set pre-pogrammed.
The info is on pg.35 of the drum owners manual at http://www.dtxperience.com/dox/dtxp4_en_om_b0.pdf. Hope this helps.
May 11, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Numark Avm02 Audio/Video Mixer with Effects Logo
116 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
