Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Monitor gone black
I use it the night and it was fine,the next morning its gone black.unplug the power cord and plug it back in and the screen is fine for about a minute and then goes black again.any help would be great.thanks wayde
  • Anonymous Dec 29, 2007
    I have experienced the same problem but when I checked the power cable it turned out to be loose connection, so unplugged the cable and plugged it again tightly. Problem solved when I turned on the monitor and PC again.
  • 149 Answers
Hi there, You do have a Hardware Problem, a Electronic Parts. If the scree is fine for about a minite and then goes black again then you may have a cold solder on the board of the monitor or a defective parts on Horrizontal Section for your screen. You may need to repalce some electronic parts. TY
Posted on Dec 22, 2007
My computer screen wont come on when i turn the computer on
mine did the same thing this morning when I started it the monitor didn't work
I unplugged the power cord & plugged it back up & it started like it was suppose to
check all the cords on the back of the tower & make sure there plugged in correctly
if it still doesn't work, the monitor may have gone out
Nov 18, 2010 | Computers & Internet
Getting a black screen and no device found. what
First unplug everything from your AC/outlets.Then systematically check every plug going to and from your screen by pulling them out one by one and reattaching them. POWER cord / VGA cord .The VGA cord looks like a D and has 15 pins it goes in easy no force is necessary, thumb tight the screws on each side.Now power cord make sure it's tight, in the socket.Then plug your AC plugs back into the wall. If that doesn't solve your problem either your screen has gone bad or your video card. Good luck!
Nov 15, 2009 | Dell Dimension 3100 PC Desktop
Computer screen is black
Two things come to mind...
If the monitor is fitted with moister sensors it will as a safety measure not turn on, this can be due to damp in the room etc.
Second and more probable is the fuse has blown on the circuit board to the monitor. you will unplug power lead open back up and look for a smaller than plug size fuse which is chrome ended and clear glassed. About 3/4 inch long and 1/8th dia.
Ensure these are replaced with a similar graded fuse. Maplins is a safe bet to obtain them. best to take old one in with you.
Nov 08, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck
Jul 24, 2008 | Star Logic 17" LCD Monitor
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
