Question about Kodak EasyShare C340 Digital Camera
The camera will not start up. symptoms similar to
The camera will not start up, symptoms similar to low battery power.
    Scholar:
  • 90 Answers
I've had the same problem and it is a very COMMON problem. Kodak should be ashamed. If you contact Kodak, they may offer to replace the camera, but you have to get a return authorization number and send your camera to them. Try that and let me know what they day. Also, with my SECOND C340 (yes, I'm a glutton for punishment), I took the batteries out and left the camera alone for a weekend. I put new batteries in and it worked like a charm.
Posted on Oct 03, 2009
I Pressure washed my 1990 Honda Civic Ef engine
Solenoid? Low battery? I've had both cause similar symptoms.
Sep 02, 2014 | 1990 Honda Civic
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
Samsung S860 won't power on. light blinks green, will not start
I had a similar problem with this camera. although its likely you have damaged the camera (seek repair from authorised Samsung dealer. should have a 1 year warranty - although you may not be able to claim accidental damage) there is always a chance the batteries are stuffed. i spent hours trying to find out what was physically damaged before realising the AA batteries did not have enough CURRENT to support the camera. gave same symptoms. some new extra heavy duty batteries did the trick.
Worth a try before footing a large repair bill
Dec 02, 2009 | Samsung S860 Digital Camera
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
Jun 17, 2009 | Samsung S850 Digital Camera
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Camera will not power on as if battery is dead ,(not battery )was working fine
Some cameras have a similar issue when the on off button gets stuck down caused by dirt or small sand particals tap on palm of hand in all axis and a cleaning with small amount of isopropal alcohol sometimes helps symptoms sound like need pro care/repair
Nov 09, 2008 | Nikon Coolpix 5400 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Low battery message, sent back to canon to repair and still having same problem..can i send back yet again. where to? or can i get a new one.
I had this same problem. I tried this procedure and it seems to have worked so far:
1. run a set of batteries down in the camera so the voltage is so low the camera won't even power up fully.
2. put some cheap (non-alkaline) batteries in and run these down.
3. get some hi-power alkaline batteries (the kind that are marketed as 'photo' batteries or similar, they do cost more) and put these in. Hopefully the 'low battery' indicator has now been reset.
This worked for me.
Nov 15, 2007 | Canon PowerShot A520 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
171 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
