Question about Whirlpool Refrigerators
The freezer is 19deg and the lower food compartment only gets to 60deg
  • 304 Answers
Model number is always valuable in order to be able to give you more accurate information.
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Defrost heater (most likely and in freezer behind rear wall), defrost thermostat (in freezer-must be checked at freezer temperature) or one of Defrost timer or Defrost control (Circuit board) generally located in Refrigerator compartment but may be inside rear of outer case. Defrost heater and defrost thermosts can be checked with an ohmmeter. Disconnect power to refrigerator, remove rear wall and disconnect at least one side of any component you are testing. If the heater and defrost thermostat test good for continuity then replace the defrost control.
Without repair refrigerator will work perfectly for about 7-10 days after being COMPLETELY defrosted, including behind freezer panel, until thick frost builds up again cutting off air flow to both compartments
Posted on Oct 03, 2009
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Kitchen Aid Unit - maybe 4-5 years old but past warranty. Freezer not freezing. Not that cold in fridge. I played with the dials 1. Are higher or lower numbers on the knob coldest? 2. What else should I...
Set dial to higher number in the fresh food compartment (large door) set the freezer
knob on the vent stack in the center or to the left (if it is set to colder, this prevents cold
air from getting into the lower fresh food compartment). Colder means the freezer
gets colder.
Also if you have a failed defrost termination thermostat it will cause this
symptom on many models. (a lot of folks will disagree but I have only seen a couple
of defrost timers fail in 10 years). The water makes its way into the defrost termination
thermostat and corrodes the contacts inside. It is behind the freezer panel and has two
wires going to it. It is clipped onto a tube. You will need the model and serial from inside
the fresh food door (on the side panel) to get a new one, usually less than 20 dollars.
Remember to set the fresh food compartment temp from 34 to 39 degrees with a
thermometer in a cup of water for 24 hours. Don't forget to unplug unit if service is
required on the thermostat. Hope this helps.
Jun 08, 2011 | KitchenAid Refrigerators
Refrigerator freezing food
Ah... where is that manual when you need it! Actually, the internet is WONDERFUL for such emergencies! I found a manual on the FixYa site for you in pdf format. It will be easier to find on your computer!
Now to the soluiton...
Generally with the top freezer designs the main thermostat controls the temperature of the freezer (which should be about -18°C or 0°F and the there is a slide control that allows a metered amount of cold air to drop down into the "fresh food" compartment.
As an immediate adjustment, turn the "Fresh Food" slider down 1 number LOWER that what it is set to at the moment. Is fresh food still freezing? Then put it down another number lower.
But you should also check the temperature of the freezer compartment with some appliance thermometer... leave it in for several hours or overnight for a proper reading if you've just added food to the freezer. It should be around -18°C or 0°F If you adjust the freezer, you may have to go back and readjust the fresh food setting.
I hope this helps! Don't forget to download the digital manual!
/denis
Dec 10, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
My refrigerator is running but my lower portion is not cooling. The freezer part is plenty cold and keeping my frozen foods frozen. Why would the lower part of the fridge not cool?
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
Aug 29, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
232 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
