Question about Sony PlayStation Portable (PSP) Console
Psp is not turing on
My psp is not getting started, when i on the power switch the light just stays for few seconds and then it just dont on. i was updating my psp software and then suddenly i off the power switch and then my psp is not getting started
  • 79 Answers
Re: psp is not turing on
Your psp is bricked, becuz you power it off while it was updating firmware.
If you running on cfw, you still got a chance to repair that.
Let me know which firmware you are running.
Posted on Dec 21, 2007
0 characters
3 Points
Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
Here are some instruction to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 04, 2011 | Video Game Consoles
    Psp not turning on..
    take out the battery and clean it and then if u have a memo stick take that out and try starting it.
    Feb 04, 2010 | Sony PlayStation Portable (PSP) Console
    Green light will stay lite for 20 seconds then shuts off any suggestions
    It should be the charge level of the psp.Switch of the psp and keep it for charge.Switch it ON only when you thing it is full.If it is still switching of get your psp a new battery
    Jan 23, 2010 | Sony PSP (Piano Black)
    Screen stays black green light comes on for a few seconds.
    This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
    Please Rate, thanks!
    Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
    I have an updating version problem
    sorry but your psp is bricked u need to buy a pandora battery and a magic memory stick to fix your psp.
    Jun 28, 2009 | Sony PlayStation Portable (PSP) Slim...
    My psp green light gets on but any thing did not come on screen
    well side by what? side by side .. ok so first of all maybe it was the internet connection......or power failure..its sony 100$ bucksl;.....or your like me go here and look at the fifth comment down!! do all that he says get all the files you need 1.5 ofw and 4.01 ofw
    and then when you run psp pandora deluxe you simply select the drive your psp is like [h] or [d] and chose the one and then chose the Ofw files you download and then chose desperato cemeterio v6 [4.01 m332] then hit format and prepare card Set the DC v6 to the left trigger and elf to Square.. and then chose more options and chose install support tools for pandora, install support tools for XMB copy 4.01 1.50 addon. then u start the psp holding square [elf menu] and then chose to run pandora installer and then chose battery options and then pandorize battery then exit out and turn off psp and the turn on while holding left trigger and then chose 4.01 ofw or 4.01 m33[ which lets ou play psp games for free snes playstation one and much more
    Jun 27, 2009 | Sony PlayStation Portable (PSP) Slim...
    New psp will not charge
    If you have multi meter at home make sure that voltage is coming from the adapter.
    if the psp have some battery backup check the battery level when u put on charge...
    Go to Settings>> System Settings>> Battery Information>>
    If you dont have the equipments to check go your nearest electronic service center or sony showroom. Take your charger with the psp so that they can find out the exact problem
    Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
    Power light
    you need a new power swich ? which you can perches of ebay
    Mar 01, 2008 | Sony PlayStation Portable (PSP) Console
    Oops,... i dropped my psp
    Hey Dude,
    All things are fixable. Try going into recovery mode. This is done by Pressing and holding the R button when powering up the PSP. You then can press the brightness control button to see the firmware. This might help you reboot the PSP. If it is worst than this, you may consoder sending it back to Sony for repair, although they usually do not want to fix a Squooshed PSP. I would not tell them you Sat on it. You can call SONY support at 1-800-345-7669.
    If you cannot get them to Repair it, you can check out my website, . I can fix it for a very reasonable price.
    Nov 01, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    Top Sony Video Game Consoles Experts
    Troy Gorman
    Troy Gorman
    Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
