Question about Kitchen Ranges
Jenn Air W256B error code F8
The lower oven self cleaned fine. Trying to self clean the top oven, the fan comes on normally, but soon an F8 error code and constant beep occur. Several attempts offer same results.
  • Kitchen Ranges Master
  • 2,605 Answers
Hi, F8 on later model jenn-air ranges/wall ovens indicates an issue with the meat probe, usually the resepticle. The fault is sensing a temp. at the probe above 250. Unless you actually have the meat probe inserted into the recepticle and the oven has heated above 250, then it's not likely the meat probe itself. Hence why the recepticle is likely faulty or in need of inspection/adjustment. Here's how (this may or may not work...sometimes it does though). First unplug the range or shut off the power to it. **The probe is attached on the oven liner via a nut, however you,ll need to gain access to the outer side of the liner by removing the side panel if the recepticle needs to be replaced, but hold on.** You nay only have to loosen the nut and re-tighten it to insure the recepticle has a good "ground" to chassis. there is only one wire attached to the other side (you can't see it) because the probe converts temperature to resistance in the control, that is why this "ground" is essential and can cause "faults" if not secure/sufficient. At times that's all it takes to force an F8 code. Try this first, reset the power and see if it yields a successful remedy. Hope that helps, good luck Hope that helps, good luck
Posted on Oct 03, 2009
Tip
Jenn-Air Oven 4D22 Fan Error
I was troubleshooting one of these error codes on a Jenn-Air oven and followed all the repair recommendations. Most service techs recommend replacing the fan, speed sensor and making sure everything is clean. I did all this and it made no difference. After a bit more troubleshooting I found the temperature sensor to be bad. I replaced the temperature sensor and the fan fault code disappeared and the oven worked normally.
on Dec 09, 2016 | Jenn-Air Ovens
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Jennair single oven...
Hey marygilfilen
F8 error is associated system failure. I suggest you need to replace your clock (controller)
Regards
Aug 19, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jul 28, 2008 | Kitchen Ranges
Jenn- Air Model W256W
hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Apr 01, 2008 | Ovens
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Kitchen Ranges Logo
638 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
