The power cord keeps overheating - Heating & Cooling
  • 58 Answers
Try to replace your power cord with a higher ampere wire.
Posted on Oct 03, 2009
  • 3,051 Answers
Hello there:
this could be a wiring problem from the factory where the cord is unable to handle the load thus resulting in the cord overheating .
Or you might have the setting too high making the unit run constantly and now getting any time to cool itself down.
i would refer to the operating instructions and do what it tells you to do and if you still recieve unsatisfactory operation i would take the machine back to the place where you purchased it. ok?
best regards michael
Hp mini laptop goes off automatically
Maybe it is overheating or losing power.
Check the Power Cord and the DC Power Jack where the power cord plugs into the laptop.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Overheating??
When the computer is overheating it will not boot back up until you let it sit a while to cool off. If your systems shuts down and does not boot right back up, then it might be overheating.
Three causes of overheating:
1) Dust - Dust inside the laptop, dust clogging the fans and vents. Dust around the cpu and heat sink. Solution - Take a can of compressed air and blow out the dust. It's best to take the laptop apart to blow it out.
2). A Fan not working. Take the laptop apart and replace the fan. Most laptops will tell you if a fan is not working.
3). The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste around the cpu and heatsink.
If your laptop is overheating you could buy a Laptop Cooling Pad from Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type: Laptop Cooling Pad in the search box and click GO. Sort the returned results by Price Low to High. I recommend the Sabrent for $12.99 which has 3 cooling fans and the laptop sites on the pad. The pad plugs into one of your usb ports.
May 28, 2012 | Computers & Internet
My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool...
Try a hard reset first unplug all the cords from the ck and allow the unit to reset for 30min and then plug in the cords back.
I will be posting more troubleshooting steps..
Goodluck..
Apr 05, 2008 | Audio Players & Recorders
My computer pc boots and goes off after a while
Sounds like it might be overheating or a virus is kicking you off. If it is overheating, then if you try to immediately try to power it back up, it will not come back successfully. If you let it sit a while and cool off then power it up and it boots successfully then you know it's overheating.
Causes of overheating:
1). Dust - dust in the fans, the vents, around the heatsink and cpu, all inside the computer.
2) A Fan that does not work.
3) The Thermal Paste around the CPU and Heatsink has either dried up or is too thin to keep the unit cool.
Good thing it's a desktop, cuz all you have to do is remove the power cord, the case and you can remedy the problem easily.
Apr 03, 2012 | Computers & Internet
My toshiba laptop keeps shutting down only when plugged in to the a/c i have a 305-6853. no overheating works fine if running of the battery alone
This is most likely issue with power cord or on the laptop where you plug it in. Try to separate the cord at adapter and just plug it in without being pluged in to power and see does it create short and shut down your laptop and if not it is possible it is not sending right voltage to the laptop it self. Try a different cord if you have one. Good luck
Mar 17, 2011 | Toshiba Satellite A305-S6859 Notebook
I got a red light on my power cord, what do I?super
A red light on a power cord for the Xbox 360 usually means it has overheated. Try unplugging the power supply and leaving it alone for awhile to cool down. Make sure to not cover the power supply when you do reconnect it to keep it well ventilated. If this doesn't work you may have to replace the faulty device.
Nov 11, 2010 | Microsoft Halo Reach for Xbox 360
It keeps cutting off
If you are using the power cord, your power supply is failing or overheating. If it is on battery, replace or fully charge the battery.
Aug 09, 2010 | Oritron Televison & Video
My Dell Vostro 1000 keeps shutting off. Cure?
I am having the same problem.
I used to think that maybe the problem was related to overheating so I I bought a cooling pad with fan. This improved the situation somewhat, but, the problem continues.
My friend thinks it is related to the power supply/power cord.
Aug 08, 2010 | Dell Vostro 1000 Notebook
Xbox keep turning off power cord light turns red
the problem is your power supply is overheating you just have to keep it in a area that is cooler or has less heat . the best bet would be turn off your xbox let thepower supply cool down and then turn it back on . you might need a replacement the same thing happend to me
Sep 23, 2009 | Microsoft Xbox 360 Console
My Emachine Pc keeps cutting off
It could be that your power supply is not putting out enough power to keep up with demand. IE.. during high graphics loads. If you upgraded your graphics card without upgrading your power supply, this could be the problem. Most PC's off the shelf are under powered and putting a video card in that requires mass power will really kill a system. Or it may be overheating. Overheating causes a varied number of problems to a PC, most of them permanent.
Also, there is a code to the beeps. The pattern of the beeps will tell you what the error is. Check with the MB manufacturer to find out what they are.
Aug 24, 2008 | E-Machines eMachines Desktop PC
Xbox keeps shutting off
Overheating problem, view the XBOX 360 forums, you,ll find answers there for your problem.
Mike @ compurepair.
Feb 24, 2008 | Microsoft Xbox 360 Console
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
