Question about Insignia IN-MP3256 MP3 Player
Insignia mp3 my computer does not recognize above get an error message there is a problem .... usb port is not connected...works ok on another pc tnx for ur help
Similar issues. Both computers wouldn't recognize all of a sudden. Out of shear frustration - I switched to an older USB cord - worked - both computers recongnized the player. This was unexpected - since the new USB cord worked fine with my other devices (camera, etc.). So - recommendation is to try a different cord.
Posted on Jun 15, 2008
    Problem Solver:
  • 8 Answers
Please provide more information on the error message.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Posted on Feb 24, 2008
Hi, I try to plug my MP3 into one of my USB ports. Doesn't recognize it. 'Removable Disk (H:)' comes up in 'My Computer', but soon disappears.
There is a problem with your USB port
you should try getting them fixed which is a tough job, but you can try plugging your removable media into another USB port like USB ports in backside of the cabinet.
If you don't find any problem with your USB device then you must have been having problem with your Removable Media (Mp3)
If your MP3 Player is under warranty period then you can look for its repair (can be done if its out of warranty too, but it will charge you extra)
Solutions To work around the above issues, one of the below solutions could prove helpful:usb-device-not-recognized.jpg
  • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed. 1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert
Aug 11, 2011 | HP Pavilion Slimline s3407c Desktop,...
Computer does not recognize Coby MP822 4G MP3 player
The actual MP3 player should display a USB connection on the screen, if not, I would say its a connection issue (bad USB cable), my guess is your using a laptop, a lot of laptops disable their USB power options, you probably need to re-enable your USB ports, if desktop, it should show a USB connection on MP3, if not, battery or cable issue.
Sep 13, 2009 | Audio Players & Recorders
Usb device not recognized !!
Dear its ur pc usb port problem. so don't worry about ur pen drive. if u change ur usb port then it become ok to ur pc. thanks
Aug 08, 2009 | Transcend T.sonic 610 MP3 Player
Insignia 1GB Kix mp3 player works in Mac OS 9, but not OS X Tiger
try using another usb port my macbook sometimes doesn't recognize my USB ports.
Or you could use parallels and run windows
Jul 06, 2009 | Insignia Kix MP3 Player
The computer does not recognize my Atak MP3 player.
My Zen Vision M Series has worked fine with my Dell Inspiron 1150 for about a year with no recognition problems. However, as of about a month ago my PC denies a connection with the Zen now. In many instances a windows message keeps appearing saying that the the usb ports cannot accomodate the connection between the two fast enough. I had minor problems with the usb ports, however, a simple reconnection resolved the problem. How can I get my computer (which is running XP) to recognize my MP3 player and might it really be a usb problem? Would appreciate any assistance mel4pat2000
Mar 31, 2009 | Audio Players & Recorders
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
Help
These units take more power than a thumb drive and sometimes the front USB ports on a computer just don't push enough current to recognize these players (I have the same issue).
Try plugging it into the back USB ports.
Also, make sure your USB ports are working correctly in your device manager.
Apr 27, 2008 | Insignia NS-DV2G MP3 Player
Computer does not recognize my camera
Try another usb port, if other usb devices work on your pc then I beleave its a hardware side fault
you can get a free repair estimate from
http://www.advancecamera.com/repair/
Mar 14, 2008 | Fuji FinePix E510 Digital Camera
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
