Question about Dell Dimension 4600 PC Desktop
I can't go internet, because I just reformat new drive and reinstall window xp on, my system is dell dimemtion 4600
    Guru:
  • 355 Answers
Find your driver from these site
1)dell.driversdown.com/dell-drivers-list/s_631_1.shtml
2) www.allegro.cc/forums/print-thread/587511
3)
Posted on Oct 03, 2009
How do you delete a failed operating system on dell 4600 using windows xp
Start to reinstall Windows XP -- one of the options will be to "format" (write 'zero' values everywhere) onto the disk-drive. Voila! EVERYTHING will be "gone".
Jun 15, 2010 | Dell Dimension 4600 PC Desktop
It is running very VERY VERY slow. I thought reinstalling windows xp and drivers may solve problem but did not. I booted the system from C drive with windows xp pro in he system. It formats the hard drive,...
You may want to check the hard drive - sounds like it may be starting to fail. When it reaches the point of not continuing does it start to click? If you hear clicking then the drive is having issues and its time for a new one.
Nov 15, 2009 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 needs to be reformatted. The Dell reinstallation OS disk boots up and gets as far as "Windows Setup....press Enter to continue". Then it freezes. I have tried using both the original...
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Jul 16, 2009 | Dell Dimension 4600 PC Desktop
Cannot reformat Dimensions 4600 I tried F11 but it won't let me restart
If you are going to reinstall the operating system on the dimension 4600, while it is on insert the Operating System CD inside the drive then press and hold the power button to turn off system. When you turn it back on press the F12 Key once on the Dell Logo and that will take you to the Boot Menu. Choose the one that says IDE or Onboard CD / DVD Drive then press enter. If it asks you to press any key to boot to the CD then press enter again. Then just follow the normal prompts for reinstalling the operating system.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
Dell dimension 4600 microphone problem
If this is a clean install (formatted drive and reinstalled) then the likelihood of it being a driver issue is greatly reduced. Did you download the drivers from Dell?
Secondly, the fact that the audio works makes me think it is a hardware issue. Since audio and the mic are connected in the device manager, the easiest solution might be to replace the sound with a PCI soundcard. They are fairly inexpensive, and they will generally include the drivers with the disk.
Dec 22, 2008 | Dell Dimension 4600 PC Desktop
Sam file
The SAM hive is the security function of Windows XP. I am surprised that you can boot to Windows at all. From your description, it sounds like you have a virus infection.
Since you cannot access the internet or run any programs, it may be simpler to just try to re-image the system.
If your system is a Dell 4600 it should be equipped with PC Restore (At boot, just after the Dell screen, you should have a black screen with a blue bar across the top for about 1 second) when that screen appears, press CNTL+F11 and you should be able to re-image your system. (This will wipe out all data, but should get the viruses too)
If that fails, or you don't have a Dell, the boot to your XP CD and reformat the HDD and install a clean copy of XP
Jun 12, 2008 | Dell Dimension 4600 PC Desktop
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Reformatting
I assume you want to reformat it and then reinstall some sort of operating system. The esiest way to do this is to reformat it during the reinstallation of the operating system. If you are using Windows XP, it gives you the option of using FAT32 or NTFS file system to format the drive. If you are using Windows 98 or ME, you can boot to the CD and use the fdisk/format commands found on the CD.
Sep 03, 2007 | Dell Dimension 4600 PC Desktop
Driver problems
JPWatson, This link will take you to the drivers for your Dimension 4600 with Windows XP: http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_P4_4600&os=WW1&osl=EN As far as the PC showing you already have a connection I would ignore that for now. Just download the appropriate drivers from this Dell page including the network interface card drivers and install them first. After you have rebooted and verified that the hardware devices are working correctly then start troubleshooting your Internet connection if it is still necessary. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 21, 2007 | Dell Dimension 4600 PC Desktop
Dell, 4600 desk top
Make sure that the System Restore option is still enabled in Windows XP. This can be done by right click on the My Computer and selecting Properties. Click on the System Restore tab and make sure the Turn off System Restore button is NOT CHECKED.
Sep 20, 2006 | Dell OptiPlex GX110 PC Desktop
Dell Dimension 4600 PC Desktop Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
