Question about JVC AV48P777 Television
I need to know what the focus panel is called'it has six knobs tuner?I dont want to pay for person to come replace cause they burnt me for 125 and my buddy told me that it was that tuner piece.anyone know part number or specific names
  • 10,594 Answers
6 knobs piece is called Focus Block and it is necessary part of rear projection TV that has 3 picture tubes to project picture on front screen.
Tuner part is covered with metal shields and usually has one Antenna In pin.
Click Focus Block to see an image (for reference only)
Click Tuner for its image, as reference.
Thanks.
Posted on Oct 03, 2009
ECU relearn ford focus
call dealer service and see if its a reprogramming issue..personally I dont have a clue..
Dec 14, 2013 | 2002 Ford Focus
How did I correct blue and red lines curved across a blank screen of my KP-57WV600 SONY Projection TV?
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue and red CRT. I don't remember if the focus block is in the front or in the back of the tv on this model. Most projections have them in the front.
You could check the back access panel and look for a black box with six knobs as descibed in step 3 below. This is what you are looking for.
follow the steps below if it is located in the front:
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
The small knob that moves the slideto the left or right on the platform (the one furthest from the observer) is slightly loose, and instead of rotating in a smooth circular motion it rotates rather...
The knob you are talking about is called the x-axis control knob. It does not directly affect the focus. What affects the focus is the slight manipulation of the stage and or slide while you are adjusting the x-axis control knob. It only takes the slightest pressure to throw the focus off very far. Theoretically you could completely remove the specimen holder and move the slide around with your fingers.
The specimen holder may need to be replaced but without further more detailed knowledge of the mechanical problem I cannot instruct further.
Oct 05, 2010 | Premiere Microscopes P-01310 Monocular...
How to adjust the lens-focus?
the lens has a wingnut knob on it, loosen the nut and then rotate the thing to focus in and out. there is also an electical focus in the front of the tv, there is a little black box called a focus block, 6 knobs , 3 focuses for each tube, 3 drive controls (screens).. dont turn the screens, just the focus for the color needed.. look closely they are labeled its just hard to see
the front should pop off, remove what screws you can find, the rest are snaps.. really tough ones.. let me know if you need further assistance.
Jun 25, 2010 | Samsung HCM4216W 42" Rear Projection...
Where is the focus control
behind the speaker grill
open up the access panel
look for the focus block - it has 6 knobs, labeled very small and hard to read, r, g, b - focus and screen
-dont move screens unless you need to change the drive of the crts.
there is also a wingnut (mechanical) focus knob on each lens, dont move unless electrical focus doesnt work
Jun 08, 2010 | Hitachi 51S500 51" Rear Projection...
Sony Screen keeps Blinking
If the red LED blinks 5 times you have a AKB error. It is caused by the CRTs trying to balance the color, and failing. Its an annoying problem that happens when the CRTs get old. If its just beginning you can balance or slightly turn up the screen voltage to the CRTs to remove the problem, if its in the end stages, the CRTs may need to be replaced. This is however, very expensive. If you are daring and safe around high voltage, pop off the speaker grille, open the front panel up and find the focus block. Don't poke around! those big red wires have 30,000 volts running through them! The focus block is a black square box with six knobs on it. Three are labeled screen, three labeled focus. You will see each row labeled R, G, B for red green and blue. The writing is tiny. Mark all three screen knobs with a colored marker so you know where they started. Then turn each one up slightly. If you have a picture, put it to a black screen or blank input. Turn each knob up just unit you see the color over drive and turn it back down to black. You want to set it just below retrace to maintain black level but drive the CRT fully. Setting this is hard but may fix an AKB issue.
Dec 02, 2008 | Sony KP-61S65 61" Rear Projection...
Magnavox rj8510 ak03 out of focus?
Thats your focus/ screen control block good luck on finding one.
Oct 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Our display board was replaced now the y sustainer board needs replaced
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
Sep 04, 2008 | Toshiba 50HP66 50 in. Plasma Television
Akai 37'
hi there it might b a little late with this as u posted this in may of 08 but my recent years of tv repair may help it could b the tuner in there older tv set had a similar problem with the tuner try opening tuner box it may need unsoldering but once in check all grounds for bad solder joints and resolder if needed the blue screen u see is normal when no signal input is found making it most likely the tuner.
May 21, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Picture is getting darker and darker
The screen/focus block assembly has caused problems with this model in the past. Sometimes it can be readjusted, other times replacement is called for.
Jan 20, 2007 | Hitachi 51F510 51" Rear Projection...
JVC AV48P777 Television Logo
48 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
