Question about Epson Aculaser C1100 Printer
Also getting four coloured dots in random positions on prints
Over the length of the page I'm getting four coloured dots printed over the length of the pages I am printing
You said over the length twice
Posted on Oct 03, 2009
My bizhub c451 suddenly started printing and copying nothing but colourful dots and lines all over the page. even with a test page i can only see a windows logo and all dots and lines, no text. even
Make sure the ink cartridge is full or new. Get to the "Maintenance" page and try an alinement. (The ink dries and will clog the jets if not used often enough.)
Jan 01, 2015 | Konica Minolta Bizhub C451...
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
We have just changed the photoconductor unit on our Epson Aculaser CX11NF printer. When we print or copy, we get coloured spots on the right hand side of the page
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Jul 07, 2009 | Office Equipment & Supplies
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Coloured dots
Maintenance - BTR Adj - Plain 1 - 5 to 8
Feb 15, 2008 | Dell 3000cn Laser Printer
Wrong colour
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Aug 13, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
215 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
