Question about HP 1TB HP Media Vault Pro mv5140
I set the Ip address manually to 192.168.1.0 and now I can not connect to the media vault and/or the control center
  • 215 Answers
The HP Media Vault includes a process allowing the customer to reset many parameters back to default factory settings; without losing data already saved to the drives. Some of the parameters that are reset:
  • Administrator user name and password
  • Workgroup
  • Time Zone
  • LED Controls
  • Language
  • Network Settings
You will need a paper clip, straighten out one of the bends in the paper clip. Locate the small opening between the USB port and the health LED. Insert the paper clip and hold the button down for 10 seconds. If you simply press and release the reset button you will simply restart the system
The following occur when you successfully reset the system.
  • Administrator password is cleared
  • Administrator user name is cleared
  • Workgroup is changed back to WORKGROUP
  • Time zone changed back to Mountain Standard Time
  • Change LED controls back to On
  • Default language is set to English
  • Network configuration is set to DHCP
  • Network name is set to "HPMediaVault"
after resetting connect to it and chage back to your custom settings.
For more details please check this link
website
frequently asked questions section
Hope this will help u
Thank you.
Posted on Oct 03, 2009
  • 922 Answers
That is not a valid IP address.
IP addresses must end with .1 to .254
I am surprised that it let you set it to zero
Best bet is to reset the media vault to factory defaults and then follow the manual to set it up. Go to support.hp.com for more info.
If this helps, please vote for my solution.
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Tip
How to set up a static IP address in Windows Vista
Static IP addresses are often used for computers that host specific services, or for computers on small, manually managed networks. To set up a static IPv4 address on a Windows Vista computer, first find an IP address that is not currently in use and is outside the DHCP assignable range (if applicable). Then follow either of the procedures below.
From the taskbar:
1. Right click on the network connection icon in the system notification tray.
2. Select Network and Sharing Center.
3. Under Tasks, select Manage network connections.
4. Right click on the network connection that you want to set up the IP address for (Local Area Connection, Wireless Network Connection, etc.)
5. Select Properties.
6. If the User Account Control window pops up, select Continue.
7. Click on Internet Protocol Version 4 (TCP/IPv4).
8. In the Properties window, click the circle next to Use the following IP address.
9. Enter the IP address that you want to assign to the computer.
10. Enter the subnet mask and default gateway. (For small or home networks, these will typically be 255.255.255.0 and 192.168.1.1, respectively.)
11. Enter the IP address of the DNS server next to Preferred DNS server.
12. If you have an alternate DNS server, enter that IP address as well.
13. Click OK to save the changes.
From the Start menu:
1. Click the Vista orb.
2. Right click on Network.
3. Follow the procedure above from step #3.
Reserving an IP address under DHCP is different from setting up a static IP address. To reserve an IP address, log into your router's configuration utility and look for a heading such as DHCP or IP Address Distribution. You will probably need either the computer's Windows name or its MAC address to reserve an IP address for it.
on Jan 30, 2011 | Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
Feb 06, 2009 | Microsoft Xbox 360 Controller
My wii cant connect to my wireless conection
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the Wii but add 1 to the last number for the IP Address as this has to be unique on your network
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wireless hook up
Windows XP
3. Click Support
4. Click Details
Windows Vista
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
PS3 access problems to media server on wrt350n
I believe a simple solution to this beings with assigning a static IP address to the PS3
IF your router is 192.168.1.1 and
your subnet mask is 255.255.255.0
and your DHCP range is 192.168.1.100 for
50 licenses to 192.168.149
The address your PS3 between 192.168.1.2 and 192.168.1.99
Configure you PS3
IP address192.168.1.3
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
DNS Address 192.168.1.1
(for the above DNS address to work you must have loaded the ISP assigned IP addresses into the router which you probably have alrready done.
Let me know if this does not work. I will respond to messages here until we resolve the issue.
Then on you router your DMZ address should be set to 192.168.1.3 (your PS3's IP Address)
Dec 24, 2007 | Linksys WRT350N Wireless Router
Ps3 wont join network
i had a simsilar problem with my nintendo wii. i also have a mac and broadband ( but that doesn't matter). if you get into your wireless router by going to 192.168.1.254 in your safari browser. go to "wireless" settings. there is a channel selection (1-7) change it to 1. that should work. if not change to 2 etc.
Apr 15, 2007 | Sony Playstation 3 (PS3) Console
HP 1TB HP Media Vault Pro mv5140  Logo
1,447 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
