Question about Dell 926 All-In-One InkJet Printer
All-in-one926 printer fax won't work
All-in-one 926 printer fax won't work. screen shows up,can get fax set up,but when try to send fsx says not connected...when it did work a little screen would pop up saying conversion.not now
    Champion:
  • 248 Answers
Get all phone lines and connections checked or replaced also usb connections
Posted on Oct 03, 2009
Some faxes won't send. Recipient will recieve a partial page and then blank pages. Then my machine will tell me there is a "remote fax error". All other functions work great. I use the phone...
The problem could be to the transmission signal. Try to set your Fax Send Speed to 9600 bps. On your printer operator panel, press Setup > Fax Setup > Dialing and Sending > Max Send Speed > select 9600. Hit Ok to save the setting.
Try to send a fax again to verify that the problem is fixed.
Sep 13, 2011 | Lexmark Prospect Pro205 Wireless...
Fax problem
But can you receive a fax from that line also?
Aug 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Photo 926 fax no dial tone
ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
Since the time changed my All In One 926 sends the fax exactly one hour after I click send
I would go into the setup on the fax machine itself and look at the configuration. If you cannot fin anything set it back to its default settings.
Mar 12, 2009 | Dell 926 All-In-One InkJet Printer
Fax won't send
Hallejuia!!! Someone from the Dell community forum posted this....it worked!!!
Yes. It has something to do with the time change. I had to go into the time in my pc and manually adjust (take off automatic daylight savings) the time. Once you do this you need to restart your system. That should take care of the issue.
Mar 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Says it's printing but it's not
Go to your "start menu" and look for "printers and faxes" then after that it should bring up a screen with your current printers and faxing machines. Make sure your Dell 926 InkJet has a little black check by it. If not then right-click the Dell InkJet and select "set as default printer". If it already is, then right-click it again and make sure it isn't paused. It will give you an option to "resume printing". After that then it should work. Make sure to also delete the old printers that may be on the computer too, the reason is because it may block out your other computer.
Jan 30, 2009 | Dell 926 All-In-One InkJet Printer
Fax
Faxing from the 926 is a pretty straight forward process.
Put your document into the document feeder (or if is only one page, put it in the scanner area)
In the menu arrow down to FAX in the menu, enter the number you want to fax to, and push START.
That will scan the document, dial the number and send the fax.
There are additional options for faxing (like delayed fax, and a number of other options which can be found in the owners manual)
Jul 17, 2008 | Dell 926 All-In-One InkJet Printer
Canon pixma mp830 printer/fax
I tried this: First, press the Fax button at the left.
Then, press the"settings" button to the right of the little screen.
Then, press the "menu" button to the right of the little screen.
The screen will then display a series of options that you can move through by using the triangular arrow keys that surround the "OK" button. Make your slections, pressing "OK" to keep what you want.
When done, press the "back" button to the right of the little screen until you return to the little screen's "home page" for teh fax.
I just did this and I hope it will work -- it sure makes sense that it ought to.
Mar 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dell 926 All-In-One InkJet Printer Logo
88 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
