My desktop will not turn on. Monitor shows no input. Fan in tower running very high. No lights on the tower.
  • 154 Answers
In this case if you monitor say no input or no signal it means the monitor connector cord are not connected properly to the motherboard. Or if you have a video card you need to plug your monitor connector to the video card. Because if you a video card and the monitor cord are connected to the motherboard the monitor will not be display. So check the monitor connector if it is correctly connected.
Regards
nicole
Posted on Oct 03, 2009
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
When I turn on the modem, all visible indicators tha it is running properly show. However, none of the inputs on the rear of the tower operate. I have checked and cleaned the fan, and none of the wiring...
Your wording is not consistent. If the monitor isn't getting any signal, how do you know that the USB ports are not working?
Does the keyboard get power -- check the caps lock, num lock lights.
If it is, check your monitor for power and re-do the connections.
Nov 10, 2012 | Gateway SX2800-01 PC Desktop
The green light turned red and now it green light
Dear,
Just disconnect the monitor data cable from PC and see, any cable discunnection message comes in Monotor. If that comes in monitor, there is no issue with it
Oct 13, 2009 | HP Compaq dx2000 Microtower PC Desktop
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Emachine tower unresponsive
Unplug the Monitor, and attempt to reconnect a seperate monitor to test. If that monitor works properly, then the problem is your regular monitor. If you do not have another monitor, Try unplugging the power from the wall jack to the tower. Then plug into another port, the reason the computer doesn't turn on is because the power outlet may be running but at a lower voltage then what is required for the computer to run at its full potential. If theese both fail, Try opening your computer and check if anything is blown out.
Feb 07, 2009 | E-Machines eMachines Desktop PC
Dell XPS 400 tower does not power up monitor?
The “self test” on the monitor displays when not plugged into a computer. This means that it’s working. The LED error code 2 and 4 means the video subsystem has a problem. Either your video card is bad or bad memory module. Try reseating video card and/or memory.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 26, 2008 | Dell XPS 200 PC Desktop
Monitor has a message input signal out of range
then.. we can clearly say that there is a problem with the tower... check for the proper power supply to the Tower... and check for the lights comingup on the tower or not..
Aug 24, 2008 | Compaq Computers & Internet
Desktop monitor
Hi
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Dec 31, 2007 | Compaq Presario 5BW284 (202493-003) PC...
T5082 keeps abruptly shutting down
Sounds like it may be overheating. If you get warning beeps on startup that sounds high, low, high low, it is overheating. you should inspect and clean the fan on the processor with a vacuum or compressed air ans also clean the power supply area with a vacuum to clear all the dust out. Inspect and wipe any other dust away from the motherboard and card inside. After restarting, it still goes off, check that the fan is running during startup. If not, the fan needs to be replaced at a nominal cost. This is an easy fix. If this all fails, let me know so we can troubleshoot everything together.
Nov 19, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
720 people viewed this question
David Payne
David Payne
