Question about Maytag Washing Machines
Door locks as it should, machine spin cycle will start, but will never reach full speed, pump drains all water out
  • Maytag Master
  • 2,605 Answers
Hi, this is an issue usually associated with a faulty door lock assy & machine control board, that' s the control in the console behind the timer. If you arr able to remove the control and visually inspect it great. Look for a resistor identified as "R11", if it looks burnt or disoloured badly (it should have stripes from left to right, gold, red, white, & orange). You'll need a new control #22002989. this is most common, but not exclusively the only possible fault, but a good place to start based on your symptoms. Hope that helps, good luck
Posted on Oct 03, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Washer does not spin cycle, why?
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 30, 2012 | Whirlpool Washing Machines
Doesn't spin
Apr 29, 2012 | Kenmore Washing Machines
Will not spin out water
Apr 25, 2012 | Kenmore Washing Machines
Apr 24, 2012 | Kenmore Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
