Question about Kodak EasyShare M1033 Digital Camera
When i go to full zoom, no matter what the setting, the camera turns off...
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
I am unable to set the Digital Zoom to On, in my Canon G12. The Digital Zoom Option in the Camera Menu always seems to stay blanked out no matter what I do. Discussions with fellow G12 owners did not...
The digital zoom setting is only available when the aspect ratio is set to 4:3. The setting is accessible by pressing the 'func.set' button in shooting mode.
Mar 17, 2011 | Canon G12 Digital Camera
Hello! I actually have a TZ3 and have been having problems with the quality of the pictures without using the zoom (grainy) as well as problems with the quality of the picture when using the zoom...
Hello, yes a few suggestions "grainy" could be from an auto ISO setting the sensor speed high as in possibly ISO 400 even 800 or higher you get the pictures but it's grainy. On pocket point and shooters this is most often the case in full automatic modes and on your camera it's called "Intelligent ISO Mode" You should consult your manual and select a more user selectable ISO speed manually. Another feature with your camera is image stabilization this you can turn on or off preferably off when the camera is mounted to a tripod. Okay for the blurry part on the zoom the quickest way to explain this is every tiny movement you make holding the camera is magnified 10 times, this is where the image stabilizing feature would be handy. Jennifer in my younger days I could hold a 35mm camera with a 300mm lens steady at 1/60 of a second now I use only a 200mm lens with image stabilization "on" to get the same results. What you have is a full time auto everything camera if it's working for you it doesn't matter if it's 3.5 years old. You are still working with a 7.2meg camera with a print capability of 11x14. hope this answered some of your questions.
Dec 28, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Turn on the unit and goes to full zoom. Back it off manually, it will immediately return to full zoom. Unit was bought new about 6 years ago.
My camera did the same....it turned out to be a sticking zoom switch. With the camera turned OFF... move the zoom button ON TOP ( above the view finder) of the camera to the left and right about 20 or 30 times... then turn the camera on and try it.... very simple... but it worked for me :o)
Gazza
Dec 04, 2010 | JVC GR-DX307 Mini DV Digital Camcorder
I have a Canon IXUS 40 how do i turn on the digital zoom
Heres the support site for that model http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=10599
I would never use the digital zoom on a camera, as you can do exacttly the same on a computer - so keep the full optical setting and the you can zoom in and crop using a PC - with a lot more control
Apr 07, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Olympus D-545 won't change settings.
Rotate the dial around a few times to refresh the contacts.
May 03, 2009 | Olympus D-545 Zoom Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
54 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
