Question about General Electric WSSH300G Front Load Washer
Washer, Front load #WCVH6260 F W W - trying to
Washer, Front load #WCVH6260 F W W - the large door gasket tore at the bottom lip and leaks water. I purchased the front door gasket - almost got it out, but how can I release the flat white clamp from the drum face? I see no screws or releases.
Terry
    President:
  • 1,304 Answers
Use a theromstat screwdriver,
ver small flat head, push it betwen the detent
and the clamp it should release right away
Posted on Oct 03, 2009
Water leaking out from bottom of door during operation
clean the glass real good,, if it still leaks take a hair dryer to the part of the gasket that seals around the door,, heat it while pulling the lip out toward you ( not much just try to get it straight) if the doesnt work you will need to replace your gasket,, also know as the bellows
Jan 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Duet leaking out the front door. They replaced
Hello LPeck, This is a pretty common issue with all front loading washers. Typically it has to do with the door bellows (gasket) that seals the door to the washer cabinet.
First, look very carefully at the gasket all the way around, using a flashlight. Pay close attention to the area where the water flows into the washer. This is usually located on the upper part of the gasket and sometimes the water inlet port gets the gasket moved out of place and when the water is flowing into the washer, it can leak outside of the gasket. Make sure that the gasket is properly located around the water inlet port and that the gasket does NOT extend past the water nozzle.
The other thing to do is again look very carefully at the entire gasket for small cuts or tears that might be allowing water to leak out. Even a small cut can allow alot of water to leak out of the wash tub, so carefully push/pull the gasket with your fingers while shining the flashlight onto it.
In almost all cases, it is a cut or torn gasket that is the source of the leak.
This is an easy self-service repair, only requiring a few basic hand tools to remove the gasket bellows from the washer cabinet and inner wash tub. Just fold the back lip from the washer cabinet and you'll see the retainer wire that holds the bellows onto the cabinet. With that removed, you can then slip the bellows gasker off the cabinet lip and see and get at the inner wash tub retaining clamp. Typically held on with a large diameter hose clamp. Remove that and you're ready to install the new one in the reverse order.
Just be sure to let the new gasket lay out to help get most of the kinks out of it, from being in the small shipping box, and install it slowly and carefully, so not to put any cuts in it.
This will save you around $150 +/- instead of having a service tech do the installation/repair for you.
If you want to see and order the part yourself, you can go to the following link to see the gasket and how it is installed. You can order it online from sears, or any place you wish.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GHW9150PW0&productCategoryId=0153200&brandId=1198&brandDescription=WHIRLPOOL&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR%20AND%20LATCH%20PARTS&documentId=W0501061&blt=06
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
the door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
May 11, 2009 | Maytag Neptune MAH6700A Front Load Washer
Mildew
all front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washer leaking
It may have torn the gasket or just have a sock stuck in it.
you can remove the bottom panel to help look.
(3 screws on bottom front lip)
remove ac power
you cannot operate with bottom door removed as it has a safety switch.
While you are down there open the filter and look for trapped debris.
ready for some water , have towels ready.
Feb 02, 2008 | Whirlpool GHW9100L Front Load Washer
Gasket around the door
HAVE NEW DOOR GASKET, HOW DO YOU GET FRONT OF MACHINE OFF?
Jan 30, 2008 | LG WM-1832C Front Load Washer
General Electric WSSH300G Front Load Washer Logo
256 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
