Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
Me thing go blink blink
Blink... blink... blink... blink...
  • bargainbin2
    bargainbin2 May 11, 2010
    What did it do?
Theft light blinking and car wont turn over
Your theft deterrent system is activated. Did you have a key made?
Apr 12, 2014 | 1999 Ford Expedition
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Oct 14, 2011 | Dell 1710 Laser Printer
TV power button comes on to turn tv on & goes right back off but nothing on screen & no sound
Hello
This could be alot of things but I tend to lean towards a power supply issue. The short story is that when your tv starts up, it checks alot of things to make sure they are correct. If one of the voltages is off, then the tv protects itself and turns back off. In my experience when they turn back off its almost always power supply issues. It could be a card pulling down the powersupply, or the neat gizmo that powers the light. But I have not seen alot of that.
Generally if its not a power supply fault that the tv just cant tolerate it will flash a code at ya. Blink blink (Im messed up and here is the number of the fault) Blink blink BLINK!
I wish I had better news, however powersupplys are one of the cheaper and easier things to fix.
Best of luck
Nov 25, 2010 | Mitsubishi CS-32307 32" TV
Clean llight blinks, owner manual said to replace
The clean light blinking is due to a fault in heating the water, it could be several other things than the heat element. Here is a link to some instructions on how to reset the control so you can use the dishwasher, it also has a list of things that could have caused the not heating situation. Let me know if you have questions.
Blinking Clean Light
Jun 14, 2010 | Kenmore 24 in. 16049 Built-in Dishwasher
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
Will not go through a compleate cycle and then the clean light comes on and blinks 7 steady blinks and stops the blinks again and i cant start the dishwasher unless i reset the dishwasher and then it does...
Hi angelbme1,
I'm Harvey the Master Plumber.
Your problem is: will not go through a compleate cycle and then the clean light comes on and blinks 7 steady blinks and stops the blinks again and i cant start the dishwasher unless i reset the dishwasher and then it does the same thing
Sounds like you have a bad control board. I don't recomend this repair to the average homeowner. You might consider the Repair Directory for a repairman. If it has a few years on it perhaps you may consider the costs of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Lost all Power to TV
My TV did the same thing today. My red light blinks 6 times. Any help would be much appreciated!
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
26 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
