Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Needs heater element - Cuisinart DGB-600BC 10-Cup Coffee Maker
  • 123 Answers
If it is over one year old you will not get any thing from that company they are hard to deal with.
Good luck.
Posted on Oct 03, 2009
I need part # for heating element 81V80D
Buy generic element from hardware store:
Copy following link to identify element and see installation tips.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
80 gallon, non-simultaneous electric heaters usually have 4500 watt elements
Avoid promotion of 'lifetime' or 'resistorized' or 'all copper' elements as a waste of your money, ... but might be beneficial by adding surge to the economy.
Apr 02, 2013 | Rheem 81VP6S/430126 Water Heater
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Water Heaters
Need to find heater elements for a vanguard water heater model 6e746a
Hello abcd. Vanguard appears to be manufactured by Rjheem
Rheem promotes that their products require specialized 'resistorized' elements or 'all copper' elements to portion larger brand-specific sales in their pocket and for no other reason.
Mar 12, 2013 | Vanguard International Water Heaters
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
Ow do i test heating element on rheem water heater
1) Copy following link for 3-step testing water heater elements.
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) You need $10-15 multimeter from local hardware
Dec 11, 2012 | Eemax EX1440SP Heating Element for SP3208...
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a rheem glas standard 30 gallon model # 81sv-30d water heater with upper and lower watages 3500. how do i know what size heating element i need?
Look on label on side of tank.
Wattage of tank will be element wattage. This is true if tank has one or two elements since both elements are never ON at same time.
Simply go to hardware store and buy 3500W element.
Take phone photo to store if needed for identification.
Wattage appears on end of each element.
http://waterheatertimer.org/images/Voltage-printed-on-element-.jpg
Feb 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I change the heating element on my 50 gallon electric Reliance 501 hot water heater? Where can I get the heating elements?
Buy elements at local hardware store or home center, like Lowes
Look at label on side of tank.
Label shows element wattage.
Element is also printed on end of element in tiny letters-numbers.
Typical elements are 4500 and 5500 watts.
Tank needs 10 gauge wire and 30 amp breaker for 5500 watt element.
Water heaters are fully repairable by homeowner.
1) Have you tested water heater to see if element is problem? You need cheap multi-meter from Home Depot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) To change element
a) turn off power
b) drain water from drain valve ... once it starts draining, loosen element slightly while tank still has weight to hold against you turning element wrench.
Here's what to do if water heater won't drain:
http://waterheatertimer.org/Water-heater-will-not-drain.html
c) open covers on tank, remove element using element-wrench from hardware store or home center.
If element won't come out:
http://waterheatertimer.org/How-to-remove-old-water-heater-element.html
d) Clean out tank if needed.
e) Replace element.
f) Fill tank entirely with water before turning on power or element will burn out.
g) Once tank is filled, and water flows steady out of tub spout, turn on power.
Each steps above is shown on following link:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) You need to buy some things:
Screw-in type (not bolt-in type) Element that matches wattage on tank label. New Element comes with washer.
Inexpensive Element wrench.
Inexpensive multimeter if you are going to test parts first.
Some pieces of pipe and hose if tank sediment needs to be cleaned out.
Washing machine hose if tank will not drain (return after job is done).
4) Also:
You need flat tip and phillips screwdriver.
Lighting to work on tank
Some WD-40 if element is stuck in place.
Garden hose to drain tank.
Shop vac and duct tape if you need to vacuum out sediment.
Tarp to protect floor and carpet
Maybe a knife to cut back insulation on wire if wire is burned at element.
Web links above go through entire process step by step.
Add a comment if you need more help, I'll be back around 5 CST
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
174 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
