Question about Samsung RS2630SH Side by Side Refrigerator
The divider is overhot
The divider between the side-by-side is so hot that you can burn yourself on it. Frost-free nothing - it's dangerous!
  • Rudy Melendez May 11, 2010
    It sounds like your timer is faulty, or their is a serious short in your wiring.
    Sergeant:
  • 272 Answers
Greetings,
I can tell you this..its most likely the condensor fan motor has stopped turning. it could have something stuck between the blades so remove back cover and find your fan motor..It will have a 5" fan blade on it. this is where you'll look for something between the blades. If nothing there. Be careful and spin the fan blade to see if it will start..If it does..It will most likely fail and you'll need a new motor. If you have a portable window fan or something like it...Have the fan blowing towards the compressor and leave it behind the refrigerator to keep air blowing and this will make your refrigerator freeze and cool...until you get a motor
Bruce
Posted on Oct 03, 2009
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
Jan 31, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
Freezer started defrosting and the sides where burning hot. I emptied it and unplugged it. The next day i plugged it in again and it froze a water bottle rather quickly but the sides where still burning...
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
Aug 22, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Whirlpool frig divider door getting hot
that is normal,, unless it will burn you,,there is a little heater in there that is to keep frost from forming and the doors sticking,,to the cabinet,, if it is getting so hot it will burn you, you will need to call a service tech out,, that is a real hard repair to do yourself
Jan 24, 2011 | Whirlpool Refrigerators
SAMSUNG FRIDGE FROSTING
some heat is normal on the outsides and center divider. how to muche will usually mean the the condesor fan may have stopped working and is unable to cool the condensor coils and compressor.this could cause it to run longer and build up frost
Sep 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
The center strip that divides the fridge and the freezer is hot to the touch -- so hot it will burn my hand. How can I fix, and is there any fire danger?
Sir,
Sounds like there is a problem in the sealed system. Remove the rear lower cover and tell me if the condenser fan is turning. While there, is the Compressor hot to the touch?
Pull the unit away from the wall and then remove the rear bottom cover. Is the condenser fan running? If it's real dirty there, unplug the unit and clean real well. In the freezer section...look on the rear wall and tell me if you see any frost building up.
Thanks Good Luck
Aug 14, 2009 | Jenn-Air Refrigerators
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
The freezer on the inside bottom gets glowing red, hot, adn water drips on it and it sizzles. Is this dangerous? Is it fixable?
this is the defrost cycle and is nothing ot worry about. the unit has a heater that comes on about every 8-12 hours to melt accumulated frost from the evap coils. this heater is alot like the coils on yous stove. it should stop heating within 30 mins and resume cooling shortly afte that. thx peyton
Feb 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frig is hot only in upper front (divider) where two doors meet.
need to see if your fan is running in the freezer side if not replace it if it is then check to see if you have frost on the back lower wall inside the freezer if you have frost then you have a defrost problem
Dec 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
127 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
