Question about Ryobi Garden
I have a ryobi grass ranger engine 22cc with and reduction gear box and electric start and pull start. I am aftera manual and fuel ratio mixture
  • 123 Answers
50 to 1 on the fuel ratio.
Posted on Oct 03, 2009
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
What is the correct fuel/oil mixture please as some sites say 25/1 whilst others state 40/1 ( which I believe is correct for the later model RCT2800AD)
I would go with 25/1, as that is always going to be safer than 40/1, too much oil might make a bit more smoke, but the engine will be happier. Too little oil and you risk bearing damage, or even worse, engine seizure.
Jan 05, 2016 | Garden
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
What is the oil-fuel mixture ratio for the Ryobi 700r grass trimmer?
33:1 to 40:1 is typical on about 95% of all line trimmers. I own (2) 700r's and one is 32:1 and the other is 40:1, you won't go wrong at 35:1 with current 2-cycle oil. Suggest using low-smoke brands.
Aug 29, 2010 | Sport & Outdoor - Others
I have a 25cc Ryobi grass trimmer I have lost the manual. I would like the fuel ratio of petrol to 2 stroke for this trimmer
http://odref.com/pdf/Ryobi/
If you have your model number, an owners manual should be here with correct mixture ratio for petro to 2 stroke oil.
Sep 14, 2009 | Ryobi Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi SS30 Problem, please help
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
284 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
