Question about Dell W3201C 32 in. LCD Television
Working on a Dell W3201C, with no video /no sound. power light comes on .
  • 2 more comments
  • Hollis Smith Oct 03, 2009
    Dell W3201c, has no display on sound on any input. Only a little buz come from the speakers.
    thanks
    I am a Tech, this LCD dell w3201c, has power, power light comes on with no display and no sound. I ghecked the power board and change the Inverter but still no video.
    thank
  • Hollis Smith Oct 04, 2009
    Hi, all the caps on the power board checked ok, with cap tester.
    The voltage on the inverter checked ok to, i will also need a logic boad ti fix the sound.
    I am a Tech, PC/ Electronic.....just need with this one.
    Thanks
    Hi, sorry about that , but Tech do ask other Tech for help. Just Dr. do, any i repair lots of Pc monitors, and i also repair TVs ....the volts on the inverter is about 18 v DC, i use one of the best cap tester in circuit and out circuit. I repair boards not change them.
    Thanks.
  • Dell Master
  • 3,866 Answers
You have a bad power supply and that would need to be replaced.. No pic no sound would be power supply unit not giving juice to the rest of the TV. I would have it serviced if I where you. If you rather do it yourself you can get the power supply here www.partstore.com. Thanks and please ACCEPT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Oct 03, 2009
  • 1 more comment
  • Grand Canyon Tech
    Grand Canyon Tech Oct 03, 2009
    Did you say you where a tech?
    Okay listen you checked the supply with what? Did you do a Hi pot QC check for faults?? You changed what inverter the master or slave?
    Here is the thing first you never said you where a tech in your problem description and you never said you changed the inverters all this information helps us in our investigation on what is causing your issue.
    What voltage are you getting at the inverters?? What output voltage is your supply giving to your inverters and decoder?
    I am really confused how you all of a sudden a Technician and you got all these things fixed?
    I am really interested in your reply Thanks
  • Grand Canyon Tech
    Its really hard for me to beleave a tech would come to a tech with questions but I will help as long as we keep the dialog positive.. If you changed the inverter fine.. Check the decoder as well make sure there is no bad capcitors anywhere in the TV let me know Thanks
  • Grand Canyon Tech
    Grand Canyon Tech Oct 05, 2009
    Yeah i think if the invertes are good the last thing to check on this would be the decoder. I wonder what cap tester you using? You said a logic board for sound hmmm that should be on the tuner/decoder logics on this TV..
    Please clikc the accept button if you find my information helpful thanks
  • 10,515 Answers
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking, clicking noise or no sound.If you have sound from the speakers (TV shows , etc) then the backlight may not be lighting
A long time coming on is a classic example of what I am detailing for you below. .These LCD's have problems with the power supply capacitors going bad,a technician will charge between $200 and $450 to repair it replacingeither the capacitors or the whole board.
Here is a DIY (do it yourself) solution:
Itcould be just a few bad capacitors on the power supply, if you want toattempt the repair yourself you can do a visual of the power board capswill appear swollen on top.We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
withthe back removed you will usually see two circuit boards the upper oneis the power supply, it has a few capacitors on it (cylindricalstanding straight up soldered in mark on the sides with thepositive/negative sides and uf and Volts values).
The power board and back unscrew with a medium Philips screwdriver,if you do not know how to De-solder and Re-solder then do not attemptthis as you may damage the TV more than fix it.I am posting a photo of some swollen caps on a board so you know what they look like :-
http://www.fixya.com/uploads/images/E702EE7.jpg
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!!
Do accept the solution, if 100% satisfied from my service!!
  • taran_2005
    taran_2005 Oct 03, 2009
    Thanks for your response!!
    Have you checked all the connections. Sometimes, loose connection might lead to all this. Try to check the connections.
    Make sure that this is not a Graphic card problem.
    Let me know, once done!!
    Guru:
  • 830 Answers
Video:
To enable the video to the TV, follow these instructions:
Plug in the original monitor and set it up for dual monitoring (see article PDF file).
http://www.oceansystems.com/dtective/dual_monitor_setup.pdf
Once you get the tv set up, you can disable the original monitor (following the same instructions above) or keep it, which I recommend.
Sound:
Are you using S-video to connect to TV? S-Video only carries the video signal so you need a way to get the audio from the tuner box to your TV card. I recommend just attaching the PC speakers to the computer unless you have a supported sound card that will allow you to connect to tv.
My dell w3201c tv displays "no video signal" when i power it on
Coaxial cable does not carry video signals but rather rf-signals
To use coax you will have to tune like you are searching for a signal from your aerial..
If you prefer to use video then you will have to use a video cable either rca or hdmi. you can then choose video or hdmi from the remote
Len
Sep 12, 2014 | Dell 221-9703 W3201C 32 INCH LCD TV...
Sound quit working
after what incident the sound stopped /
Jan 19, 2008 | Dell W3201C 32 in. LCD Television
Dell w3201c no sound from the speakers. will it work if i connect the tv into a different speakers?
I had the same thing happen, I used external system and the sound worked. You can't get the sound board fixed. I tried. Dell TVs stink. And there customer service are no help.
Jan 31, 2014 | Dell W3201C 32 in. LCD Television
Sound
this could be the audio video board I'm 95% sure about that
May 13, 2010 | Dell W3201C 32 in. LCD Television
I also have problems with DELL!!!!! (W3201C.....32" LCD TV)
Try putting your mute button on for about 20 mins or so and the problem may clear up. This solution has worked for me for a few days now.
Yaletown 53
Aug 19, 2008 | Dell W3201C 32 in. LCD Television
Dell W3201C blinking power light (but powers on)
if u have main board signal, its your power board. it needs to be removed, replaced and researhed on ebay. if unable to locate, email me.
May 23, 2008 | Dell W3201C 32 in. LCD Television
Dell W3201C no sound after two years....
Try pressing "LAST" on the remote control, this works on mine, although I suffered no sound within months of buying mine!
This fix works for me every day, its a pain, but it works for me.
May 07, 2008 | Dell W3201C 32 in. LCD Television
Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Dec 04, 2007 | Dell W3201C 32 in. LCD Television
Screen Blackout
Don't bother with DELL if out of warranty, they can't fix it. Have the same model and same problem
Nov 18, 2007 | Dell W3201C 32 in. LCD Television
Dell W3201C 32 in. LCD Television Logo
155 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
