Question about StarTech.com (ATXPOWER350) 350-Watt Power Supply
Doesn't work, but fuse is OK
StarTech ATX 350 W power supply doesn't work, but fuse is OK
    Problem Solver:
  • 13 Answers
Check all your rectifiers and caps.
Posted on Oct 03, 2009
What is the power supply of elite group p4m800-m?
you can use ATX version of this motherboard. 450W is prefer.
Feb 04, 2011 | EliteGroup ECS P4M800-M Socket...
I have presently a atx 350w power supply would yours solve my supply problem
If your ATX switch mode power supply is faulty then I suggest you replace it with a new one that is 350 watt or higher wattage.
Fixing faulty ATX power supplies is not a DIY project, there are dangerous voltages in these power supplies and can cause death or serious injuries.
Jan 30, 2011 | AMD Codegen 350W ATX P4 Recommended...
I am looking for a power supply thats compatible with the CoolerMaster CAC-to5-uw
should take a standard atx 12v power supply. i believe that came with a 350 watt ps. try here
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010090058%201131310111&bop=And&ActiveSearchResult=True&Order=PRICE
Mar 05, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
How many amps does a 350 watts power supply have?
should be written on the power supply on a specs sticker
hop this helps
Jan 03, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Power Supply Bestec ATX-300-12EB3- Rev: s4(S) 300-watts
yes if you can get the side plates unscrewed and the backplate plate uncrewed then the sides should lift off of the power supply now if you look at the board where all of the wires are it should be on the side by the power cord they are pretty small and some of them are soldered in so be carefull ok keep me posted ook best regards mike
Aug 23, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
POWER SUPPLY
ATX PSU are enabled by a signal on the green wire pin 16.
Shorting of pin 16 to ground (0VDC) will enable the PSU
Refer HERE
Also refer HERE for the 20 PIN ATX
Jul 01, 2008 | Intel (ATX350P4) 350-Watt Power Supply
150 W ATX Power Supply HP-150SS
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
StarTech.com (ATXPOWER350) 350-Watt Power Supply Logo
49 people viewed this question
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
