Question about Craftsman Garden
18.5 Intek OHV Briggs-DLT3000 Craftsman - Won't start - backfires
18.5 Intek OHV Briggs - DLT 3000 Craftsman (Model # 917.275821 SN # 071905c001284) - I bought it in 2005 and it has never failed. I was mowing yesterday and I turned it off to close a gate. I got back on it and it wouldn't start - just backfired as I was trying to start. I disconnected the fuel line into the carb and it was pumping fuel out. I checked for spark on end of plug and it was jumping to the frame. I looked to make sure the flywheel key was not sheered - it is all fine. I sprayed quick start in the opening to the carb and it wouldn't even begin to fire. It feels like it is getting compression when I manually turn it. I am at a loss at what to try next. Anyone?
  • skylarsdad Oct 04, 2009
    I replaced the seat switch, but found out that the mower will turn over with or without the seat switch even plugged in. This used to not be the case because my son would need my help to start it because he was too short to reach the pedal and still sit on the seat so I would hold the pedal in while he sat and turned the key. It is definitley electrical, but not the switch itself. Any suggestions. Thanks in advance.
  • Brian Snoddy Apr 01, 2012
    I am having the exact some problem with mine. I had it running and then turned it off next day wouldn't start. Like you I checked the gas, spart, flywheel all fine. Did you find out what the issue was?
    Sergeant:
  • Craftsman Expert
  • 417 Answers
These guys are all wrong. Remove the valve cover and inspect the two pushrods, one (exhaust most likely) may have come off the rocker arm or is bent or even snapped.
Posted on Nov 21, 2013
Pull the flywheel off and I think you'll find the keyway is sheered. Looking down from the top it looks as though it is not sheered but more than likely it is. Quick enough way to know for sure.
Posted on Mar 03, 2013
I have the exact same problem. It was running fine then next time i went to start it it wouldnt start. I checked the fuel, spart, flywheel all are fine. Did you find the issue with yours?
Posted on Apr 01, 2012
  • 123 Answers
Check the switch under the seat.
Posted on Oct 03, 2009
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Garden Logo
1,794 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
