Question about Jensen XA4150 Car Audio Amplifier
How many watts RMS are? - Jensen XA4150 Car Audio Amplifier
  • 655 Answers
Hello melesk82,
The Jensen XA4150 is a 4-channel amp that outputs 75 watts times 4 channels into a 4 ohm impedance.
Hope this helps.
Posted on Oct 03, 2009
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
Watts rms?
It is the root mean square (abbreviated RMS or rms), roughly 0.707 of the peak wattage of an AC source. Crutchfield lists it at >power range: 2-110 watts RMS (450 watts peak power)
Sep 16, 2013 | Kenwood KFC-6986 Coaxial Car Speaker
How many watts does this amp put out
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
Feb 19, 2012 | Alpine MRP-M650 Car Audio Amplifier
I would like to know how watts or rms is it
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
Sep 12, 2010 | Power Acoustik LT-980/2 Car Audio...
Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
How many watts is it?
KA3 offers 125 watts RMS at 4 ohms, 200 watts RMS at 2 ohms, and 250 watts at 1 ohm. The high-current section offers 50 and 75 watts RMS at 4 and 2 ohms, respectively
Sep 30, 2009 | Jensen KA3 Car Audio Amplifier
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Jensen XA4150 Car Audio Amplifier Logo
98 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
