Question about Cell Phones
Jawbone original seems to go into sleep mode. If I have not received a call for a short time, the Jawbone seems to go into sleep mode and I am unable to answer an incoming call with it. I have to answer the call on the phone and then try transferring over to Jawbone. I also lose bluetooth connection during the middle of a call.....
  • 127 Answers
I have a Jawbone and have not experienced those problems. You may have a connection issue with your phone. Maybe the way your blue tooth is set on the phone....power settings?
Posted on Oct 17, 2009
Kenmore 70121 air conditioner
There should be a sleep mode button on the remote. Press this then pres ok/enter.
Note: In this "MODE" the selected temperature will increase by 2 degrees F 30 minutes after the mode is selected. The temperature will then increase by another 2 degrees F after an additional 30 minutes. This new temperature will be maintained for 7 hours before it returns to the originally selected temperature. This ends the "Sleep" MODE and the unit will continue to operate as originally programmed. The "Sleep" MODE program can be canceled at any time during operation by pressing; Sleep MODE, "On/Off", "Fan Only" or the "V//X" buttons, on either the Control or the Remote. "Time Delay Stop" limit reached will also end "sleep" MODE.
Jun 01, 2012 | Kenmore Heating & Cooling
How do i pair my jawbone bluetooth headset to my envy touch?
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY!"
Jan 19, 2011 | LG enV Touch VX11000 Cell Phone
Jawbone not connect with phone
Is the jawbone in pairing mode (this means either a solid light on the jawbone by pressing and holding the button. Or it could be a flashing light. Either way you need to be in pairing mode for your phone to discover it.once it is pairing mode the pairing code is "0000" put this in and the light should flash off on the bluetooth
Aug 26, 2009 | Motorola Cell Phones
I have a jawbone bluetoothe and i want to program it to my cell phone
The instruction that come with the Jawbone don't give exact instructions for making it go into pairing mode AFTER it's done it the first time... here is the way to do it on a new phone:
Summary
New Jawbone pairing troubleshooting
You can view this answer at
http://aliph.custhelp.com/cgi-bin/aliph.cfg/php/enduser/std_adp.php?p_faqid=96
Jul 31, 2009 | Cell Phones
Iphone does not ring when in sleep mode
This seemed to work for me;
1.) Reset the phones network settings
2.) Reboot the phone
3.) Put the phone in airplane mode
4.) Reboot the phone
5.) Take the phone out of airplane mode
6.) reboot the phone.
I read this on another website, and it seemed to work for me.
To reboot the iphone hold down the sleep/wake button, and the home button at the same time for 6 seconds (until the apple logo appears).
Good Luck!!
Jul 27, 2009 | BoxWave Corporation Apple iPhone 2G...
Can't connect my jawbone with my phone
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY! "
Jun 02, 2009 | LG Vu CU920 Cellular Phone
HP monitor staying in sleep mode
I don't know if this qualifies as a solution or not, but to-date, the only solution I have found has been to never upgrade the video driver beyond the original "Spring 2007 Original NVIDIA Graphics Driver", installed via sp26865.exe that I got from HP support when my system was new. This file does not appear to be available now, but the support group may give it to you on special request.
Every time I "upgrade" the NVIDIA drivers, my monitor will not come out of sleep mode and only restoring to the original will work. I do not know if the upgraded driver fixes any of the advertised problems or not since I do not seem to suffer them.
Apr 09, 2009 | HP Pavilion w22 22" LCD Monitor
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Trying to use sleep mode, no manual or original remote
do a google search on the model of your tv..and you will find the original remote available most of the time for only a few bucks..........
Feb 03, 2008 | Philips 55PW9363 55" Rear Projection...
Cell Phones Logo
172 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
