Question about Maytag Neptune MDG5500AW Gas Dryer
Squeaky noise when the drum turns - Maytag Neptune MDG5500AW Gas Dryer
    Problem Solver:
  • 13 Answers
When you remove the housing check all your rollers and bearings. If it still squeaks it may be as easy as the level of your dryer.
Posted on Oct 03, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
SQUEAKY DRUM!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jun 07, 2010 | Fisher and Paykel DE08 Gas Dryer
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Makes a squeaky sound then stops for the last
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Sometimes the belt slips off the idler arm brackett or motor and will not allow the drum to turn.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This could be your saueaky sound you describe if not this will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 14, 2009 | Crosley CDE6000 Electric Dryer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
132 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
