Question about Intel D865PERL Motherboard
My D865PERL will not boot past the first screen that provides the model number,version, amount of RAM, and other info. It recognizes the keyboard and mouse. At the bottom of the screen it offers the option press F2 to enter setup and F12 to boot to network. It stops right there no matter what key is pressed. For the past several months it would hang there but it would boot after pushing the reset button. Now it will not boot at all
  • 2,019 Answers
Any error codes?. BIOS will beep codes if it detects problems. Try removing all the periferals, incase they are screwing up the plug'N'play routines. But otherwise, I would say the MB may be toast.
Posted on Oct 03, 2009
How to fix gigabyte ga g31m es2c after long period of use now . i can power on but freeze after start screen appears.no keys on keyboard are functional .what the real trouble? is there any solution?
Sometimes it can be something simple like the ps2 cable from keyboard has dislodged.check all cables.any bleep codes should be noted.i.e.three bleeps usually unseated/ failed ram chips.
best solution would be hirens. Boot disk which will install a small Xp version on ram and allow diagnostics and fixes to be carried out.you will need to create a bootable USB or burn a disc.google hirens 15.2.if no joy you may consider the fault is coming from boot sector which is root kit problem.the solution sometimes is to remove drive and fix it on another machine then reinstall it.
Nov 28, 2014 | Gigabyte Computers & Internet
Compaq CQ50 wont load
YOU are to be COMMENDED!
Do you know how many do not even post the manufacturer name of the computer, much less the model number?
Plus adding the diagnostic measures you have posted?
Wish more people would use the problem area you have used, and wrote a PAGE! lol!
Do need the model number though, along with the model series number you posted. This way I can look at the BIOS versions.
(Example - CQ50-100CA)
Need to ask.........is CDROM the first boot device in Boot Options?
(BIOS Setup)
Could be of course, but you didn't post it. Makes a BIG difference.
The computer HAS to boot from the CDROM, then.
Post back in a Comment.
Regards,
joecoolvette
Mar 06, 2013 | Computers & Internet
My hard works but me screen will not come on after installing 2 GB of ram , but the screen works when I put in the 1 GB of ram...
A) ALWAYS helps if you post the laptop manufacturer name, and model number.
Model number is on the Bottom of the laptop.
B) EACH Ram Memory slot has a MAXIMUM Amount of ram memory it will support.
If the TOTAL Maximum Amount for the laptop is 2GB, plus there are two Ram Memory slots, and the Maximum Amount for EACH ram memory slot is 1GB, what you are doing = NO.
Awaiting laptop manufacturer name, and model number.
C) Also, post what you see on the 2GB ram memory module, or info elsewhere for it.
Need to know WHO made it, and what it's specifications are.
May NOT be for YOUR laptop.
Regards,
joecoolvette
Feb 16, 2013 | Computers & Internet
My computer has a RAMDDR2 but would not start up,can u help me diagnose and troubleshoot?
First make sure you haven't installed too much memory. The computer uses DDR 2 memory but what is the maximum amount it can use. If it can only support 2mb and you have 4 installed the computer will read that as an error during boot up. Second, disconnect the Keyboard and as the computer is booting access the BIOS. disable the stop on all errors setting so it can get past not sensing the keyboard and see if that boots. If the computer boots after that the problem is a fault in your keyboard like a stuck key which will give you the constant beep. If you see the spalsh or BIOS screens then the problem is not the Video Card. If you don't get those screens double check and make sure the Video card is properly installed with nothing installed in a slot directly below it as this sometimes causes conflicts.
Nov 17, 2011 | EliteGroup P4M800-M7 Motherboard
How do i find the memory slot on my Advent Quantum Q100?
The Advent Quantum Q100 laptop has one Ram memory slot.
The Maximum Total Amount of Ram Memory is 2GB.
It uses SO-DIMM ram memory that is DDR2 at 667 MegaHertz. (667MHz)
Also known as PC2-5300 {SO-DIMM style}
The Ram Memory slot is under the Keyboard.
Past this point I am at a loss to describe how to remove the Keyboard.
1) Either you have to remove the LED cover above the Keyboard, and below the LCD screen to access screws which hold the Keyboard in place, (Computer off, and ALL power removed. AC adapter {Charger}, and Battery),
OR,
2) The LED cover (Power On button, LED's, etc, are in the cover), has to be removed, and there may be one, or two screws coming up from the bottom of the laptop, which hold the Keyboard in place.
Regards,
joecoolvette
Jun 26, 2011 | Advent Computers & Internet
Have a Intell D865PERL getting either 6 or 7 beeps when booting, can't be sure which. System will not boot but just beep with PS2 keyboard installed but will boot with keyboard removed. BIOS is version...
It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
Feb 01, 2011 | Intel D865PERL Motherboard
Executing OTP version 3.04
Hook a VGA monitor, keyboard and mouse up to it. Then turn it on to see if it's booting into Windows or even into the BIOS. If it's booting into Windows, then download your autoloader firmware from Rimage.com (click the support link, then your model, download the autoloader firmware) -- then unzip it somewhere on your Rimage and use Gemini Utilities to update the firmware in the autoloader. Then restart the computer and see if you still see the same message.
The printer being recognized is tied very closely to the autoloader firmware working. Also, it helps to make sure the printer's switch is set to the position marked for Transport.
Apr 15, 2010 | Rimage DiscLab DL5200 (555101120) Burner
E machine wont recognize the moniter or keyboard
With the limited info that you provided, it seems like the motherboard is not functioning. When you turn the computer on, does anything happen in the box?
Jul 17, 2009 | Computers & Internet
Etower 633id runs very slow. Only has 64MB of RAM.
Normally upgrading bios does not require flashing the bios. But in order to find out the max amount you can upgrade too requires some info off the motherboard. You need to get the model number off the board to look up the info
Dec 24, 2008 | E-Machines etower 633id PC Desktop
Intel D865PERL Motherboard Logo
329 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
