Question about Denon AVR 2808Ci Receiver
I am having trouble getting two channel direct mode to work. Sound comes from the sub woofer but not the left and right channel. Receiver works fine in in dolby digital and simulated sound processing modes. Already tried the A & B speaker on/off switches.
  • mrzoro Oct 06, 2009
    I have re-checked the connections and they appear correct. I did neglect to mention in my initilal message that the two channel direct stereo was working in the past. I have scrolled through numerous options in the menu list (using the TV for viewing those options) but did not see anything that would lead me to correct the problem. Any additional thoughts?
  • 3,267 Answers
If this problem is during Radio operation viz.AM reception then it is so because all radio broadcasting in mono sound format. If this is happening no matter which component is switched on. If you are getting sound when using dolby Digital setting that indicates the speakers are OK. If you want to make only stereo then you have to select 2.1 speaker configuration to get the L & R speakers plus the sub-woofer(2.1).If this mode is not selected it use default settings which now-a-day's are min. 5.1 channels....sodeep
Posted on Oct 06, 2009
    President:
  • 1,734 Answers
Most probably you are plugging the speaker in the wrong socket. Sub A in Preset out is for a powered sub woofer. The speakers should be going to the bottom row of connections that are marked Front A , center and surround Zone 1. We need to test a basic setup first. See if this is enough to get the unit to recognize the speakers. Please note that the speakers have to be connected to the terminals using twin flex for each one , top and bottom in each set, marked +, and -
Posted on Oct 03, 2009
Sound only coming from 3 of 6 speakers
A 5.1 sound card will give output in all channels only if the audio being played is also 5.1.
Normally out of 6 Speakers only 2 front and sub woofer will play sound, in case of a DVD or Movie which has 5.1 encoding, all 5 will come alive.
Also, Dolby Prologic II and Dolby Digital will convert a 2 channel input into psudo 5.1 enviornment but Dolby has to be in hardware or speakers or Receiver.
Jan 21, 2014 | Creative Labs MegaWorks THX 550 Computer...
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a Onyko TX-SR303 5.1 Receiver and sound is only coming out of left front speaker.
Could be the IC that controls the various sound/surround channel modes. Had that happen on my Pioneer receiver.
Charged me close to 200 bucks to fix!
Aug 24, 2017 | Onkyo TX-SR303 Receiver
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Sub Woofer will not work with my other two speakers.
ok SB is for surrond back. but i think i now what the problem is. if your receiver is in multi channel decoding some times the bass will olny come out of your main speakers. and how to change this is go to SET UP in main menu on your receiver make sure you got NORM SET on and then go over in tell it has your main speakers highlited and change that to SMALL not LARGE and sarry for the spelling hope i helped
Mar 06, 2009 | Sony STR-DE597 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Denon AVR 2808Ci Receiver Logo
50 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
