Question about Soyo SY-P4I 845PE Motherboard
I am trying to install SY-P4I 845PE motherboard into a case... need help with arranging the cables from my case to right pins on the motherboard
  • 788 Answers
This board is a oldie...
Its going to be slow with the 3 ISA slots.
Anyway, most important is the 24 pin power connector and above to the right is a 4- pin video plug, which you must have to complete your video output.
Next, close to the CPU holder is a 3 - pin CPU fan connection.
Next, your IDE drives, you may want to check your pinout on the cables you are using.
Next, is the USB connections.
Sound, power on, turbo, reset and leds should all be together on one block.
Hope this has helped you.
Posted on Oct 03, 2009
Can I use a p4 3.2 processor with 800mhz fsb?
If the 3.2 is a prescott, I would doubt it. This was a board ahead of its time in 2002, and i seem to recall, took the (then) latest P4 3.06 chip. You MIGHT be lucky and the worse that could happen is the board Bios would not recognise the chip, or run it at a lower clock speed
Dec 31, 2010 | Soyo SY-P4I 845PE ISA (SY-845PEISA)...
I want to change my pentim 4 cpu 1.70ghz.256 ram.motherboard Intel i845 chipset, Intel southbridge 82,801 (ICH2). if I could turn it into pentium core2duo and what should I change or add?
Your motherboard is already maxed-out - no bigger processor is available.
You need a new one, with new memory and a new video card. Or just buy a new pc, it will be cheaper in the end if you aren't a gamer.
Mar 08, 2010 | Soyo SY-P4I 845PE Motherboard
What is the fastest processor this board will handle?
i thought
Intel i845PEis fastest processor for your board
Feb 12, 2010 | Soyo SY-P4I 845PE Motherboard
Need the layout of the USB plugs? 4pins in one row 5pins in second row.
Normal USB pinout is as follows:
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
Pin 5 is universally a second power, so it may not always be used.
Your motherboard may have the pin #1 marked but if not, standard is for the #1 pin to be closest to the CPU. Your manual should show this, if you have it.
Good Luck
Jan 07, 2010 | Soyo SY-P4I 845PE Motherboard
Soyo SY-P4I845GVISA Plus will not see USB keyboard
Go to the setup program and enable the "Legacy USB Support".
Nov 03, 2009 | Soyo SY-P4I 845PE Motherboard
My psu went out i have a soyo sy p41845pe mb what the highest watt psu i can get for it
you can have any power supply you want on it aslong as its the right size for the case say for example you went out and bought a 1000W power supply you system would use around 200-400W depending whats installed it just means the other 600W dosnt get used
Sep 25, 2009 | Soyo SY-P4I 845PE Motherboard
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
Sony DVD ROM 52x/32x/52x/15x Ultra Speed
Can you see a small hole at the bottom to the left or right of the draw or even below it. If you can and can get your hands on a paper clip, very gently insert the paper clip. That should release the draw.
Failing that, and depending what you have insode the draw it may be worth you buying a new one.?
Jun 16, 2008 | Soyo SY-P4I 845PE Motherboard
Soyo SY-P4I 845PE Motherboard Logo
202 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
