Question about HP Pavilion dv6000z Notebook
My hp dv6000 pointing device is not working correctly it goes crazy when i try to use it
  • 788 Answers
This mouse touch pad is very sensitive to outside devices.
If you are using any external devices, disconnect them and try the fallowing.
Go to your device manager and find mouse or pointing devices and remove them.
Save and reboot the unit.
The unit will find the correct drivers which are loaded on your hard drive under SWsetup.
After loading the drivers and the unit has settled into a idle mode, reboot the unit and check the operation of the mouse-touch pad.
If this has taken care of the problem, load whatever devices you were using, one at a time.
If you notice the mouse starts acting up, it will be one of the external devices you have connected.
If the mouse still does not correctly and you are not using any external devices, you may want to disable the mouse-touch pad and hook up a USB mouse. ( Standard or wireless ).
I hope this has helped you.
Posted on Oct 03, 2009
I have a HP Pavilion dv6000 and the webcam does not work , i also tried everything still i couldn't use my web cam
did you try update correct drivers and reboot system?drivers is here -
http://www.hp.com/united-states/products/dv6000.html
Nov 15, 2012 | HP Pavilion dv6000z Notebook
Cant get my hp PAVILION DV6000 built-in webcam to work.
try using a real HP driver yet?
downloaded from whom, most non HP sites are virus pits from H3LL.
know that first.
finding drivers for obsolete systems is super hard work.
Pavilion dv6000 (is that the full partnumber or the useless series number)? post the service tag for 10x better answers.
if at HP.com (where you should have gone first) they demand that first. that is because, there are 50 LT in that series.or more
and guess what they all dont use the same chips nor cameras.
carbon date,,,, 2006 ,2007?
just about 10 years old and support ends at 10 years old
XP is dead now for 3 years why run XP
XP must have SP3 loaded, service pack 3 or USB is no good and vast other things super bad.. (old old history that)
only this matters, see those xx below, all facts here matter.
1,2,3 , all do. to match drivers; to OS. just 1 example here of 1000
9000-ppec2icix4tk32ykqb2dko55-5-0.jpg here is the dead files on this LT
deep dead.
http://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/Windows-7-Upgrade-Guide-for-dv6000-dv9000-models/td-p/179816
if you read the real service manual on any HP laptop made
you learn fast there are vast variances in chips used.
and matching drivers same,
some have 3 -4 wifi chips different. in one model.
like this DV6000-1234, see that 1234, vast models exist.
world wide in fact.
Apr 07, 2017 | HP Pavilion dv6000t Notebook
No sound on my hp pavillion dv6000
Dear Vahomerep, First of all, make sure that your sound output is not muted. If it is in normal mode i.e. unmuted then please check your audio driver is installed properly and it is the correct one for your device. If you found any discrepancy in the audio driver then please remove it from the control panel - add remove programs and then reinstall the correct driver for your device. If the problem still occurs then please take your DV6000 to a specialist/expert.
Thanks
Sakhawat1979
Nov 29, 2010 | HP Pavilion dv6000z Notebook
No souds
is the mute button above the keyboard pressed? Are you running windows 7? Does the soundcard show up in your device manager? Also, on windows 7, the volume mixer provides separate channels for applications, rather than devices as in xp. Click the volume icon, open mixer, and check to see if the internet and other applications are muted. I use a DV6000 and this caused me trouble since this computer had a bad GPU that I fixed, which causes the ssound to stop working when it goes bad. The computer ended up being fine, I had simply forgot about the mixer.
If that doesn't work, try re-installing the sound drivers. If that doesn't work, you might have a faulty BGA (nvidia) chip, which will have to be reflown.
Mar 29, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion Dv6 1030us the touchpad won't work.. It moves okay but It doesn't click! The buttons work fine, the only problem is with the touchpad and is driving me crazy! =/
Try going to the control panel > mouse settings, Open the mouse settings and at the top of the page, there should be a tab for device settings. Click on this tab, It should bring up the touchpad device, highlight it and click on the settings button. When the settings window shows, scroll down to tapping, highlight tapping and make sure that the box is checked for tapping enabled. While you are in there go through all the other settings.
Jan 06, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Wireless Broadcom 802.11 problems
Hello hskaggs,
At this point you have tried the various troubleshooting procedures and have determined that the wireless card is faulty. To save yourself alot of time and effort, I would advise you to buy an external wireless adapter and disable the faulty internal one. Yes, it is a pain but going through this routine just to connect is not ideal.
- Vincent
Nov 21, 2008 | Acer TravelMate 240 Notebook
Cant turn my built in webcam on??
This is known Webcam issue in DV6000 notebooks. To resolve or narrow down the issue, we have to check few things.
First open Device Manager.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Imagining Devices and check if the HP Webcam is listed under it.
If Webcam is not listed there, then you have to contact HP to get the BIOS update.
If it is listed there, right click on it and select Disable. Again right click on it and select Enable.
Now open any applications like Quickplay and check if Webcam is working or not.
Please reply me if that won't resolve the issue, I can provide more work arounds
Aug 09, 2008 | HP Pavilion dv6000z Notebook
HP Officejet J5780 - NO SCAN OPTIONS
Problem Solved. I'm not sure what exactly was the answer but here is the steps I followed. First I went to the HP website and followed their procedure to uninstall hidden devices (namely duplicate HP devices). I uninstalled all of the devices. Then (with the USB cable still attached) I deleted the Printer and Scanner from Control Panel. At this point I disconnected the USB cable (the cable worked but the software wouldn't recognize the cable was attached). With the cable unattached, I uninstalled all the HP software with the 'remove software' program in control panel. The I used the original disk for the printer and reinstalled the software. Eventually the installation process prompted me to reinstall the USB cable. It was at this point the software started to recognize the cable again. And here is the best part, after the software finished installing the 'Scan To' button started working correctly!!!!
Feb 24, 2008 | HP Officejet J5780 All-In-One InkJet...
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
