Question about Fasco GSW Hot Water Heater Exhaust Draft Inducer Blower # 63172
Gsw heater pilot stays lit, but when the main
Gsw heater pilot stays lit, but when the main burner cuts in it shuts everything down . Tried a new thermocouple and it worked for a few minutes andshut down. Then the pilot would no longer remain lit.
    Problem Solver:
  • 13 Answers
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Posted on Oct 03, 2009
Testimonial: "Thanks for replying so quickly"
No hot water and when you switch pilot lite switch it runs and shuts off. Any idea what this could be?
Posted on Aug 05, 2010
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
New Reliance gas water heater won't stay lit
There is a sensor that shuts off the gas to the burner if a flame isn't detected within a few seconds. It will usually look like a tube that extends into flame of the burner. It may be defective or it may just need to be repositioned so more of it is directly in the flame.
Mar 17, 2014 | Reliance Water Heaters
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
The pilot will not stay lit after water in tank reaches desired temperature. After tank cools down pilot will relight and heat water again thyen goes out approximately 1-2 minute3s after water has been...
Thermocouple is getting weak... the extra heat from the main burner will keep it lit but after it goes out the thermocouple will then shut down..
Replace the thermocouple...
heatman101
Apr 30, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot will stay lit but burner goes out about 1 minute after it lights
The thermocouple is bad. You get the thermocouple very hot when lighting it, but then it cools down a bit even with the main flame on, and it shuts the burner down.
Replace the thermocouple and you will be good again.
heatman101
Mar 26, 2010 | Water Heaters
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Cant get my waterheater lighter to reignite
Sounds like the gas valve has failed. The gas valve can be replaced. It will unscrew out of the tank. Shut the water supply to the tank off and get the new gas ready to screw in. Take out the old and screw in the new, you will onlt lose about a cup or two of water if you are quick enough. Otherwise drain the tank down if you must. If you are going to replace the gas valve I would also replace the thermocoupler.
Dec 18, 2008 | Water Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Fasco GSW Hot Water Heater Exhaust Draft Inducer Blower # 63172 Logo
393 people viewed this question
Top Fasco Water Heaters Experts
Gil Shultz
Gene Haynes
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
