Question about Asrock P4 COMBO P4/S478+LGA775/848P/DDR400/SATA/A&L/ATX Motherboard (MOTASR28)
Does it support 1 tera hard disk ?? - Asrock P4 COMBO P4/S478+LGA775/848P/DDR400/SATA/A&L/ATX Motherboard (MOTASR28)
    Guru:
  • 355 Answers
I think yes try it or find nearest delar to wether the board support or not
Posted on Oct 03, 2009
How to recover capacity of Hard drive
Use Windows disk management utility and reformat de hard disk, simple, fast and easy
Oct 19, 2016 | Hard Computers & Internet
Tip
What is the difference between "DISK" and "CD"
<p>Disks are four kinds<br /><br />1- floppy disk small space size (1.44 M ) easy damage <br /><br />2- hard disk big space more fast (HD) from 1.5 GB to 1000 GB ( 1 tera ) easy use ,Difficult damage <br /><br />3- Compatible Disk cd start size from 200 MB to 8.7 GB, easy use easy move <br /><br />4- flash disk easy use easy move start size from 32 MB to 32GB (as i see) <br /><br />wish i'm helpful <br /> <p> <br /> <p> <br /> <p><br /><img src="nadereleraki_0.jpg" /><br />best regardes<br /> <span><a href="http://www.webanswers.com/share-question.cfm?q=what-is-the-difference-between-disk-and-cd-782c68">Share</a> ' <a href="http://www.webanswers.com/answer/1967137/technology-computers/computer-hardware/what-is-the-difference-between-disk-and-cd-782c68">Link</a> </span>
on Mar 31, 2011 | Computers & Internet
1 tera segate external hard disk not reconginzed and malfuntioned
If the hard drive has malfunctioned, chances are it must be replaced. Depending on the problem may or may no be able to extract the files, if it's completely dead you will not be able to extract and transfer.
Mar 18, 2012 | Seagate FreeAgent® GoFlex? Desk 3TB Hard...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Difficulty retrieving files off 4GB hard drive via
Try Tera Copy 2.05
download
www.codesector.com/teracopy.php
Mar 22, 2010 | US Modular (USMD4GB) 4 GB Hard Drive
External HDD can not be used.
Click on the Start Button and right click on Computer and select Manage; expand the Storage section and select Disk Management; click your external hard disk, right click on it and select format; when you will be asked what file system you want to be used select the default option - NTFS; Apply, OK.
Jan 04, 2010 | Buffalo Technology 1.0 TB Tera Station Pro...
Will Asus p5ld2-vm SE MOTHERBOARD support 1 tera-byte hard disk? i hav 2gb ram
Yes it should. The issue is not so much with the motherboard supporting the hard drive. It is more the question of whether or not the power supply will support the power required to run it along with all of the other additions.
Jan 03, 2010 | ASUS P5LD2-VM Motherboard
Wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Jun 09, 2009 | Western Digital 500GB My Book World...
Cant locate it on computer
Hi...ok lets try this..go and click the Control Panel then find and click the Administrative Tools then (double Click) find Computer Management(double click) and find the Disk Management then (once) then find what HDDrive you need..Thanks and GOD Bless..^_^
May 09, 2009 | Computers & Internet
Gateway PC
sounds more like a power supply issue as these are both powered directly by the power supply. check your power cables inside the case and make sure you didnt bump them or leave them disconnected when you installed the harddrive.
Aug 28, 2008 | Intel D845GRG Motherboard
Computers & Internet Logo
83 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
