Question about Stanley Bostitch STB-MIIIFS Flooring Stapler
Air leaks thru portals on cap after replacing rings and gaskets?
I had air leaks through the air portals on the cap. I shoot one or two staples into floor and it stopped. Now it doesn't stop and the staples don't come out. I replaced all o rings and gaskets according to instructions on o ring repair kit (ORK6) and still the same problem. Can you help?
    Problem Solver:
  • 14 Answers
Remove the bumper cap and black exhaust hood from the gun. The three screws that hold the plunger to the poppet need to have lock washers and BLUE locktight on them. Clean them totally and reassemble.
Posted on Jan 11, 2010
Air leaks when triggered and no nail
Make sure no nails in gun. With air connected listen for leaking thru nose of the gun also. If leaking thru nose slightly, air is getting past the cylinder seal oring and/or top of cyl is not seating against headvalve. Repair leak to nose of gun before trying to fix head leak. With no air leaking thru nose of gun, add plenty of white grease to orings in the head (one oring at a time) to see if leak is less and/or grease will streak behind the leaking oring. Then repair as needed. May need slightly thicker oring or sand surface where oring makes contact to remove scratches that are allowing air to pass. Also air can enter the head thru the small port in the gasket leading to the head (make sure that the gasket is sealing).
Nov 05, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Sns45xp senco dosent shoot anl leak air for the cap
You have worn or broken o-rings in your upper firing and trigger system. You need a Senco repair kit #YK0230 to fix your problem. Fairly easy to do, replace one o-ring at a time to make sure you get them back in place properly and use the grease in the kit liberally. Since you'll have it apart I also recommend you get Senco repair kit #YK0231 which is the lower seals and piston stop. If the upper rings are going bad the lower rings won't be far behind.
Feb 03, 2011 | Senco SNS45XP 16Gauge Construction Stapler
Air passes througt the trigger and won" t shoot
must dissemble the trigger mechanism and replace the broken or worn o ring that directs the air to the firing chamber.
Nov 25, 2010 | Stanley /Bostitch Sb 150SX Factory...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Had a few years and never used, then used a few times using about 4 refills on staples. Wnt to use after not using for a week and when the trigger is pulled it only sends a small amount of air thru and...
remove top cap and grease all o-rings (replace if worn or cracked) if air leaks when you pull the trigger then the problem is most likely with your firing valve either worn/old o-rings or firing valve my be stuck
Nov 29, 2009 | Air Tools & Compressors
The gun will only set crown staples half way. Also, it has begun to shoot two staples at once from time to time. How can I fix it?
Begin with replacing orings and gaskets. and oil internal parts. check all air fittings for leaks and that should take care of it.
Nov 03, 2009 | Coleman Powermate 024 0179CT 2 In 1...
Oil Leak around oil cap and Air Filter
blown head gasket. the coolant gotten into the oil.
Jun 01, 2009 | 1998 Volkswagen Jetta
I have a Senco Palm nailer. It works but there is a small air leak all the time. I am guessing it is one of the o-rings but not sure which one.
There are 3 reasons an air leak can take place on this tool.
1) Most likely your o-rings are worn.
2) If the leak is coming from between the head cap and the body, at the gasket. The gasket may need to be replaced.
3) Very unlikely, The body is worn where the o-rings contact the housing.
If it is not a gasket problem, open the tool and look at each o-ring. If any are worn, or have a small inconsistency replace it.
Here is a breakdown of Senco's current Palm Nailer.
http://www.senco.com/pdf/us-pc/pc0701_nfa001_11_23_99.pdf
Apr 20, 2009 | Senco Air Tools & Compressors
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Stanley Bostitch STB-MIIIFS Flooring Stapler Logo
593 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
