Question about Panasonic TC-P50C1 Plasma TV
Can you connect surround sound to panasonic tc-p4c1 without optical wire. Just have AV wires
5 Suggested Answers
SOURCE: Surround sound link to new panasonic
come out of audio and go into what on the surround sound
Posted on Jul 03, 2008
jerryg50
  • 1667 Answers
SOURCE: panasonic veira not working with the PS3 optical output
This sounds like a protocol compatiblity problem with the medias you are using. Check the set-up for the audio in all the devices connected to the TV set. Some of the older recordings and medias must have the sound set to simple stereo or mono. If there is no digital 5.1 data on the media source there is no way you are going to hear the sound if the equipment is set to that mode.
Jerry G.
Posted on Jan 17, 2009
DigitalPlus1
  • 105 Answers
SOURCE: i have my panasonic surround
Make sure you are in a "surround" mode. It might just be in a stereo mode now which is LF,RF, and sub. Since there is no model number, I'm going to guess, but most Panys have 2 buttons towrd the bottom. One labeled movies and the other music (or something similar). Press the movie button. Look for Dolby PLII, Dolby PLx, or something similar. If the video out of the unit is connected to the TV you can check the speaker levels. Some models will do a test tone to make sure all the speakers are connected and you have them in the right location. Some models even allow to chose between 3.1, 5.1, and 7.1. If this is a new unit it will default to the highest setting.
Please rate if this was helpful.
Posted on Apr 07, 2011
bshldn
  • 736 Answers
SOURCE: TC-P50GT25 Viera has no audio
In that case all you can do is connect each device you're connecting to the television to the surround sound. You would connect the device to the television for video only and connect the sound cables to the surround sound. You may also be able to connect the devices directly to the surround sound (video and audio) and then connect it to one of the television's inputs.
Posted on May 07, 2011
How can attach external speakers with RCA plugs or a mini-plug? Is the digital audio output the only connection for audio output? (The model is TC-P50G25)
Well isn't this just a find how do you do!!
It appears that on this set there is no headset or other audio connection other then the optical?
It appears the only way to a traditional RCA audio jack is via a special adapter. See image. Inexpensive not sure of the quality of audio.
The best way would be to purchase a sourround sound speaker amp system with 5 speakers plus base woofer. These surround sound systems are usually have optical connected and for best results this would be my first choice.
Some have wireless back speakers to allow for easier installation.
RCA RT2781BE 1000W Home Theater System with Bluetooth This unit has two optical inputs and one digital input.
This is an inexpensive surround sound speaker system that should connect to your Panasonic TV optical output. Very available and I wanted to give you at least one option. Wires etc are a mess but the surround sound can be amazing. I would check all the reviews if you decide to go with this type of audio system. They can be confusing and in your case you need to have input control of volume with optical.
The following link is the manual for this particular Home theater System.
http://rcaav.com/wp-content/uploads/2014/11/RT2781BE_IB_0708.pdf
These audio systems can be very expensive. Less expenesive sorround can still provide great listening results.
Hope this helps?
Mar 03, 2016 | Panasonic Tc-p50g20 Viera G20 Series 50"...
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
Optical port problems
a suggestion, take it back and tell them when you opened the box it was this way--a whole pc board is likely to have to be replaced that has the connection on it.
Dec 23, 2012 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
I get surround sound whenever i'm playing dvd's. But how do i hookup surround sound when just watching television? I have a 46 inch Sony Bravia LCD TV and a Panasonic SA-HT700 surround sound and HD...
just plug your satellite and dvd player in to your tv. and simply take an extra set of red, white, yellow wires and us use the red and white wires to connect fron your tv output to your surround sound system's input. now you should have surround sound for everything included local tv stations from your tv antenna
Aug 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Hi, I just purchased a Panasonic Blu-ray Disc Plaer DMP-BD35. I am attempting to play the audio through a Yamaha HTR-6230 AV Receiver with 5.1 surround sound. I am using an optical cable. I am unable...
Check both for Optical
1) Check your DVD player make sure it is set to Dolby Digital or Optical Out or even AUTO (if applicable)
2) Check the Input source to the receiver say if you are using DVD on the receiver make sure the digital setting is set to either Optical or Auto
Nov 25, 2008 | Panasonic Televison & Video
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Panasonic TC-P50C1 Plasma TV Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
